Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Jul 2014
    Nope.
    Jan 2009
    Is it actually wet, or is the surface has just become shiny and polished due to wear?
    Quote Originally Posted by bokswager View Post
    that's not wet. that's shiney dry.
    turn off the engine, and put your finger to it, and be convinced.
    the belt surface gets shiney because with use, the surface is polished shiney.
    it seems, somewhere in its roundabout trip, that side passes over a very fine or shiney metal surface.
    normal.
    Jul 2014
    normal.
    Copy sir, hindi ko pa nitry hawakan, usually nag inspect the car after drive home from work, usually inaangat ko ang bonnet pra mabilis magpalamig ng engine. So noticed that shiney thing don sa belt nya.
    Ilan kms na? Papalitan mo na. Wala mura lang naman yan saka mabilis lang papalitan.
    Jul 2014
    72k na natakbo sir. Yon bang belt nya sa baba yan ba yun serpentine belt?
    Papalitan mo na. Anong model ba? Isang mahabang belt lang yan
    about lifting the bonnet to cool down the engine faster...
    i don't.
    unless we are going to tinker with the engine, which is usually nicer if it were cooler ...why want to make engine cool down faster?
    it's an engine.
    it's not a living thing.
    "we are bestowing characteristics of living things, to an inanimate object."
    Jul 2014
    i don't.
    it's an engine.
    Agreed with you, atleast from time to time nakikita ko lang loob ng engine bay at naoobserve ko whats happening under the hood.
    that's a good reason.
    Apr 2014
    Nakita ko na ng clear.
    Pulley po yan. Either from the tensioner or idler/guide pulley.
    Normal po na makintab yan since metal sya at dinadaanan sya ng belt pag naandar.
    Jul 2014
    Quote Originally Posted by midnytwarrior View Post
    Nothing to worry pa ba ako sir?
    May 2009
    i don't.
    it's an engine.
    I was taught that after a long drive, specifically in high temperature weather, it's a good idea to raise the hood in order to allow more engine heat to dissipate faster. Especially since there is no more airflow going into the engine bay where temps can sometimes go higher when the coolant is no longer circulating as well.
    It also allows the plastics, rubber hoses and other components to cool down more quickly so that they last longer.
    Yay or Nay?
    Sorry OT.
    On the topic though, the belt does look shiny and not wet. If it's wet then you need to check your gaskets sir.
    Quote Originally Posted by sparc179 View Post
    Yay or Nay?
    Sorry OT.
    maybe in my younger days.
    nowadays, i just turn off the engine, pull the key, and go to the ref in the house.
    take a much closer look, sir.
    that shiney thing is the tensioner pulley. the belt is seen underneath, on the alternator pulley. it ain't shiney. it is partly hidden by the longitudinal shadow cast by the heavy electric cable over it.
    Apr 2014
    Sa nakikita ko parang un polished side ng isang pulley either ng water pump, idler, or tensioner. At un belt is sa ilalim nya nadaan (sorry hinde talaga clear).
    Pwede nyo po check sa owners manual para makita yun route ng belt. So pag belt mismo yun nasa visible side ng picture at ang nakikita is yun ribbed side ng belt sa part na yan at makinis at makintab na sya is baka waiting for replacement na.
    If yun non-ribbed side nya ang supposedly na makikita sa side na yan, then pwede nyo po check as mentioned na pasadahan ng daliri para malaman kung basa. Pero kung makintab is normal lang lalo na sa serpentine belts.
    i made a mistake.
    tama si midnight warrior.
    the belt is seen, under the heavy electric cable, riding the alternator pulley.
    while the tensioner pulley may not be shiney upon purchase, regular use after installation will make it shiney, like that.
    nothing to worry about, po.
    i replace it, not when it gets shiney, but when the bearing goes bad.
    my non-honda's is still fine, after over 130K km...
    Jan 2009
    A shiny tensioner pulley surface is normal and nothing to be concerned about.
    The tensioner pulley is a semi-long term wear and tear part. Two failure modes are typical: Bearing wear and/or tensioner damper wear. These problems can cause excessive noise or pulley play and/or excessive belt vibration, respectively.
    Most other failure modes can be attributed to other engine problems or as a result of catastrophic failures and factory defects.
    Jul 2014
    Thank you guys for the inputs. Papasadahan ko nalang for the next PMS if due for replacement na talaga. More power tsikot!!
    Apr 2005
    Napansin ko yung drive belt Altis ko parang may tahi sa outer part. Tapos ngaun parang lumalalim na yung tahi. is that a sign to replace?
Drive belt engine
