Results 1 to 10 of 22
- Jul 2014
- 31
October 28th, 2019 08:51 PM #1
- Oct 2012
- 4,851
October 28th, 2019 10:21 PM #3
Is it actually wet, or is the surface has just become shiny and polished due to wear?
- 52,727
October 28th, 2019 10:26 PM #4that's not wet. that's shiney dry.
turn off the engine, and put your finger to it, and be convinced.
the belt surface gets shiney because with use, the surface is polished shiney.
it seems, somewhere in its roundabout trip, that side passes over a very fine or shiney metal surface.
normal.
October 28th, 2019 10:42 PM #5
Sa nakikita ko parang un polished side ng isang pulley either ng water pump, idler, or tensioner. At un belt is sa ilalim nya nadaan (sorry hinde talaga clear).
Pwede nyo po check sa owners manual para makita yun route ng belt. So pag belt mismo yun nasa visible side ng picture at ang nakikita is yun ribbed side ng belt sa part na yan at makinis at makintab na sya is baka waiting for replacement na.
If yun non-ribbed side nya ang supposedly na makikita sa side na yan, then pwede nyo po check as mentioned na pasadahan ng daliri para malaman kung basa. Pero kung makintab is normal lang lalo na sa serpentine belts.
- Jul 2014
- 31
October 29th, 2019 10:38 AM #6
October 29th, 2019 10:41 AM #7
- 52,727
October 29th, 2019 10:42 AM #8about lifting the bonnet to cool down the engine faster...
i don't.
unless we are going to tinker with the engine, which is usually nicer if it were cooler ...why want to make engine cool down faster?
it's an engine.
it's not a living thing.
"we are bestowing characteristics of living things, to an inanimate object."
heh heh.Last edited by dr. d; October 29th, 2019 at 10:46 AM.
- Jul 2014
- 31
October 29th, 2019 10:53 AM #9
- Jul 2014
- 31
October 29th, 2019 10:55 AM #10
