Results 1 to 6 of 6
February 10th, 2008 09:42 PM #1
may kalansing sa engine bay na hindi ko mahanap ung source... seems na nangagaling sa mga belts o bearing ng mga umiikot na parts (eg. ung bilog na kinakapitan ng belts?)..not realy sure... but if anyone can tell which part of the engine could possibly make this kind of sound maraming salamat.... tumutunog lang sya pag mainit na ung makina...
February 11th, 2008 12:45 PM #2
basain mo yun suspekted belt. if it disappear huli mo na. otherwise you'll have to remove each belt until you find out where it is coming from.
February 12th, 2008 09:38 AM #3
Better bring your vehicle to a shop that has a mechanics stethoscope para ma isolate.
- Jan 2008
- 154
February 12th, 2008 10:26 AM #4dude try mo lagyan ng kandila ung fanbelt mu lagay mu while the engine is running
make sure lang na mahaba yung kandila tapos need ma-rub ng candle wax sa belt
sa ilalim ha, ung tinatamaan ng mga pulley's
hold it tightly baka kasi sumama sa pagikot ng belt yung kandila
make sure lng na ma-rub yung kadila
at dapat nasa safe na lugar ung mga kamay mo,, malayo sa fan
hanap ka ng place na safe para i-posisyon kamay mo
pag nawala yung ingay ibig sabihin you need to change your belt, manipis na yan,,
if hindi pa din at feel mu sa loob ng camshaft gear nangagaling
off mo engine mo try checking yung timing belt at tensionaire( adjusting component na kinakabitan ng timing belt) baka sira na bearing, need mo na palitan yun
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 13th, 2008 12:58 PM #6
ako naman pag mainit na ung makina nawawala... medyo napansin ko rin hirap humatak ung auto ko ngayon... any ideas on what to check?
Xiaomi E-Car
