Page 1 of 2 12 LastLast
Results 1 to 20 of 42
    Aug 2020
    I had an experienced with js asakashi c-0076 installed on my mux 2017 2.5 mt 4jk1-tc. The anti drain back valve (ADBV) did not work, the oil in the filter will go back to the sump after resting for 8 hours. The oil filter is horizontally installed in the engine. For your info mga bossing.
    Quote Originally Posted by waldnerdoe View Post
    have you been using this particular brand/model for long?
    san nyo po nabili?
    is it possible, you are using a fake item?
    san nyo po nabili?
    worry ko baka OK naman yung brand, pero rep nung kalaban na brand
    https://www.tsikot.com/forums/search...rchid=10948411
    Jan 2009
    Would be interesting to know how you came up to that conclusion.
    eto yun testing na ginawa bro
    Good Oil Filter and Oil
    Jan 2009
    As with anything, some works better than others.
    IMO.... again, my opinion. I think the ADBV works best with the filter mounted vertically or near-vertical, with the thread at the bottom. Gravity will pull the oil down and force the ADBV closed. With the filter mounted horizontally, there's less force applied in closing the ADBV, so expect some oil to seep back out the inlet holes.
    Also, oil permeates through the filter media and if you remove the filter, oil will leak out the outlet port. That's normal.
    And last thing, the oil typically flows as such....
    Sump > pump > filter > oil galleries > moving parts > sump
    When you turn off the engine, oil left in the galleries, moving parts, and most internal engine surfaces, flows back to the sump. That's the reason you get a higher dipstick reading when the engine has not been running for a while. The "extra" oil did not all come from the oil filter.
    bro ibig sabihin nagkamali assessment si waldnerdoe?
    medyo naparanoid din kasi ako sa post nya kasi last year gumamit din ako nung brand na yun for my vios
    i am wondering,
    if the oil filter draining issue is a significant one,
    why don't car manufacturers design engines with oil filters mounted vertically, with the thread up?
    that should solve dry-filter syndrome.
    Jan 2009
    I have no experience with that oil filter.
    Anyway, ganito lang yan.... oil filters are relatively cheap. If you're not confident with one brand/model, you can try a different one and see if it works better for you. But you should adhere to two things: The oil filter must be from a reputable brand...not to mention, genuine. 2nd, it should be designed or compatible to your vehicle.
    Personally, I'm satisfied with Wix for my 2.5 Innova Diesel. They're a reputable brand and many reviewers online who have cut them open gave it good grades. Though, I must admit that haven't gone through the actual testing myself but then again, if these oil filters were anything but good, we would've heard something about them causing engine failures. But I have seen none of those so far.
    Dec 2013
    There is a possibility thay you may have encountered a defective filter if that's the case. Since one of the official distributors of VIC filters is already carrying JS Asakashi filters as well. So I doubt that one defective filter damages the whole brand besides JS Asakashi filter is also sold in Australia, Russia, Singapore, Malaysia, Sri Lanka, Brunei and etc... if they are a bad quality filter then other countries will not buy their product. If one the offical VIC filter distributor is shifting on selling JS Asakashi filters then that signals something about VIC filters. Do you have any proof of testing about what your saying is true? It's hard to believe in just hearsays of a new member without testing evidences, proper facts and examinations. Do you have any proof of testing about what your saying is true? It's hard to believe in just hearsays of a new member without testing evidences, proper facts and examinations.
    There is a video online showing a testing of Dai-wa, VIC and JS Asakashi oil filters.
    Dai-wa, VIC & JS Asakashi oil filter pressure test 2020 - YouTube
    Dec 2013
    By the way guys I found videos of air filters on Youtube, they tested the filtration capabilities of K&N, BMG, WIX, Purolator and etc... and the myths of K&N, BMG and other washable filters have been finally debunked. Here are the testing videos about O.E. vs. washable performance filters.
    The tests shows that bigger micron flour, sand and iron dusts can pass through more on the washable performance filters with the oil applied on them than standard O.E. type filters. What more for the smaller sized particles like fine particles from electric powerplants, factories, cement dusts, brake dusts and etc... it will wear the engine faster than its normal life.
    1st video by Project Farm
    Which Car Air Filter is Best? Let's find out! Fram, K&N, Wix, Purolator, & AC Delco showdown - YouTube
    2nd video by bhvrdr
    Do performance air filters like BMC, K&N, Sprint let more sand and dust than OEM and is it worth it? - YouTube
    Dec 2013
    I'm also curious on what kind of measures did you determine that the oil filter ADBV is leaking, did you hold it horizontally, vertically & etc...?
    Aug 2020
    Quote Originally Posted by JapanABC View Post
    Watch this oil filter anti drain back valve - YouTube oil filter anti drain back valve - YouTube
    That's not a valid test of the adbv's performance. Dapat vertical yung orientation ng filter, same as it would be when installed. The adbv is usually a simple plastic or rubber membrane that falls to the bottom of the filter to block the holes using gravity and the weight of the oil itself to hold it there. If you hold it 90 degrees horizontal then the adbv won't necessarily mate to the surface.
    adbv is piece #4 in this diagram. how it works should be obvious, as is the bad methodology of the test in those videos.
    Aug 2020
    These filters were designed to be installed horizontally on the 4jk1-tc engine... try to look at the first gen isuzu mux 2.5
    i am curious,
    after an overnight's sleep,
    will the better ADBV-equipped oil filter still have significant volume of oil inside it?
    That's the engine where the filter is installed from underneath the car right? In that case with the oil filter mounted so low the adbv should be making very little difference.
    The oil filter is already near or at the lowest part of that section of the car and there's nowhere for the oil to flow downward from the filter without being pulled upward by the pump.
    Dec 2013
    I'm afraid sir this has totally discredit you for supplying false information on this forums. You have taught a lot of people here in this forum the incorrect ways of testing an oil filter.
    Aug 2020
    Hello sir, i am not trying to discredit the manufacturer or supplying false information. I am just trying to show my experience with regards to the oil filter and for the members to see the adbv difference between vic and js asakashi. This filter may be defective. If you want i can send you a new js asakashi oil filter coz i still have two pcs in my custody.
    Aug 2020
    hello sir, where is the false info that i posted?
Bad oil filters
