Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    May 2012
    Guys what is the benefits of replacing my OEM spark plugs with Iridium or platinum spark plugs? Is it worth the price? I replace those SP every 10k kilometers and I don't feel any changes every time I replace them.parehas lang ng nagamit at yung bago. BTW this is for my APV,G16A na matanda pa sa lolo ko ahahahahahaha.
    Quote Originally Posted by jyg1995 View Post
    Jyg, iridium spark plugs can last up to 40k to 50k Kms.
    Jun 2010
    not worth it! stick to oem spec SP and base on my personal experience they dont last that long, sa civic ko isa pa sa cause ng erratic idling.
    Who recommended changing the spark plugs every 10000kms?
    May 2012
    Servicing casa ko po sir and it is indicated sa user manual, beneficial po ba na mag shift dun sa Iridium and Platinum? If yes which is better Iridium or Platinum?
    Ask your service advisor regarding change interval for Iridiums. If it is every 60k then its way cheaper. And fc is abit better with iridiums. Tested this with a 2.7 fortuner.
    Jul 2011
    Sa rav4 gen 2 (yr 2004) ko every 100k daw ang palit sa irridium, siguro sa Jan 2015 magpapalit na ako, 9 yrs is not bad kahit na mahal sha vs ordinary SP.
    Sent via LaTE Network
    Aug 2012
    Quote Originally Posted by Manilablock View Post
    Be careful sa pagbili ng Iridium. Denso Iridium spark plug is rated for 20k km only.
    Denso Iridium Long Life (OEM) spark plug is rated for 100k km. kaya lang, hindi nagpapasok ng Denso Iridium Long Life ang local distributor.
    NGK G-Power Platinum spark plug is rated for 48k km. NGK G-Power Platinum is available in most auto supply shops so ito gamit ko.
    NGK Platinum IX spark plug is rated for 65k to 80k km.
    NGK Laser Platinum spark plug is rated for 120k to 160k km.
    Mar 2018
    Magkano price sir nang NGK? May mga fake po ba neto nang maiwasan.
    Jan 2016
    I wonder if I should replace my spark plugs already? My FB will be 5 years old in July but only at 60k kms and it starts well and the engine runs just fine. Pwede ko kaya sagadin hanggang 100k kms or till tell tale signs appear? Btw, what kind of syptoms indicate need for sp replacement, if ever I push it past 5 years?
    If your manual states 100k, and it's still running ok, di pa kailangan.
    Sent from my SM-T705 using Tapatalk
    Even if it is rated for 100k it is good practice to visually check your spark plug for wear or any other indications. Sometime worn plugs initially produce very subtle manifestations medyo keen ka dapat. Without symptoms or looking 60k in a honda fb your sparkplugs might still be in fine condition especially if you use good fuel.
    Yes may fake na NGK. Denso im not sure.
    While iridium might be considered "better" than ordinary plugs there are some cars that just require and perform most efficient on ordinary copper plugs. Check your manual nga.
    Noon i remember ngk pang sedan BKr or bke ata na ngk plugs nasa mga 108pesos yung denso equivalent model 95pesos per plug.
    Feb 2021
    Quote Originally Posted by red_one View Post
    May idea po kayo kung magkano ang genuine denso iridium at NGK Platinum spark plug?
    Quote Originally Posted by Allan17 View Post
    NGK Platinum spark plug set of 4, sa altis and vios nasa 600 plus (basta less than 700)
    For which car ba? Yung mga typical Iridium for NA engines mga 600 to 700 each. For turbocharged engines, mas mahal (1k to 1.5k) pero up to 120k km yung life.
    Yung NGK Laser Iridum na OEM plugs for the EJ25 WRX/STI (ILFR6B) $11.60 lang from Amazon or $12.03 from NGK.com. Shipping from Amazon is $13 so parang isang extra spark plug, total gastos = P2,950 for a set of four plugs, landed na dito.
    Never needed to change them though. I have them inspected every year or four oil changes and still look like new even 14 years later. I'll try to dig up pics from my last inspection but they literally look brand new.
    May 2012
    Thanks manilablock and stockengine.
    May 2012
    Another question sir,which brand is better NGK Iridium or Denso Iridium?
    I prefer Denso. They have an office in Banawe. They have a complete catalogue for all vehicles. They are professional(they answered all my questions and showed and gave me the corroded copper plugs lol) and offer free installation. I tried looking for NGK Fortuner-specific spark plugs. It was difficult to find.
Iridium or Platinum Spark Plugs VS OEM?
