How often do you change your engine oils? Casa uses semisynthetic on my Captiva and I change oils every 5K. What brand do you use? What would you recommend kung every 5k ka palit ng oil? Pag fully synthetic, do you change oil every 10k?
on a diesel engine, usually every 5k regardless of type of oil you use.
but better check your manual first and follow their recommendation.
Actually it depends on the filter you using. Oil last much longer than 5000k but if it becomes dirty due to poor filtration then it does not get it's full use. Engine oil analysis show that even the good old dyno oil is good for 10000K to 12000k with a quality oil filter. That's the factory recommended oil change interval on most new diesel in the US. Fuel quality in the Philippines hampers that a little bit but 10000k with a good filter like Baldwin or Fleetguard is easy. Changing it at 5000k is wasting money.
Of course if your under warranty your stuck with the dealership OEM filter. There a big difference between a filter that is 98.7% efficient at 40 microns vs one that is the same efficiency at 20 microns and one that can hold 2 to 3 times the grams in dirt and that is still 50 percent efficient at 12 to 10 microns is a huge difference.
Get a Fleet filter they are designed to extend your oil change intervals and save you money on oil changes while having much better filtering. But if you have a canister filter your out of luck and stuck with OEM.
But if your stuck with Casa service until your warranty expires go with the best oil you can get, like Motul, Redline, Royal Purple, Delo, Mobil Delvac, ect. Only use oil that has a API rating don't cheap out.
Plenty of oil information on the bypass filter thread we cover it in depth.
Generally if you use ordinary oil, it is 5K. If it's synthetic full, it is 10k.
Not always true.
Using a different type of oil does not automatically extend oil change intervals unless the engine can take advantage of the properties of the synthetic oil. If the oil gets dirty, it gets dirty, and must be changed. The idea that "fully synthetic" automatically means longer intervals is one that many ZZ-equipped Corolla owners have discovered to be, sadly, not applicable in their case. (look up Toyota sludge issues)
Many CRDis already require fully synthetic oil, but still use 5,000 km intervals for local conditions. This is because Philippine conditions are considered harsh. This is not to say that the oil is useless by 5,000 kilometers, but unless you have access to an analyzer, do you want to take the risk?
I use Zic or Kixx semi synthetic oil for my Tucson and Santa Fe. Change oil every 5000kms since mura Lang naman yung oil. 1,150 pesos per gallon lang yung oil. 2 gallons needed.
Ilan liters ang oil ng Captiva?
I already used Motul CRDi Specific. Parang yung Kixx Lang eh. Mahal pa. So sayang Kung papalitan ko every 5000kms. Ayoko naman isugal hanggang 10000kms yung engine oil kasi madumi talaga kapag diesel engine.
I used Kixx oil for my Captiva on my last oil change (80K PMS) I got the 6 Liter container available at Seiring. The Captiva uses 6.2 L of oil. Tamang tama lang yung 6 liters na kinuha ko. It's a lot cheaper than what casa sells and other semisynth and full synth oils. Maganda naman siya and it has the same specs as the Motul crdi specific oil. I'll stick to this brand and change oil every 5k. I beleieve it can last 10k with good filter but I don't know if i can find one fleet filter. Satisfied ako with Kixx . Engine seems smoother than with the oil from casa.
how much sir yung KIXX oil? parang napakamura naman nakita ko sa online storeLubricants | Fleet Fuel Philippines for PhP3,500 you will get 3x 6L of kixx oil.....
mga sir yung KIXX OIL ba ng sinasabi nio nabibili sa Seiring ay ito KIXX D1 API CI-4 10W-40? and how much?
I had gone through the post.; I did the first oil change at 15k km when yearly 20k km was recommended. Now, In the next oil change we did at 20k km. This was good enough for the CRDI car with VGT. Please produce some more attachment links for the detailed view of the topic? Thanks in advance.
quick oil change coupons
How about sa 2010 toyota innova diesel? I know na need ang CI-4 motor oil sa 2KD-FTV as well pero ang question ko is can I use petron's TREKKER oil? I checked the bottle and it says na it's a CI-4 type of oil. Ayoko kasi masalinan ng ibang langis eh. Baka in the long run, using the wrong oil will give me a headache..![]()
Kung ang sabi ng label ay CI-4 class ang langis eh syempre compatible yan sa makina. Wag mo ipaghalo ang langis, drain all the old oil and changed full volume of fresh lube oil.
Regarding the 20K change oil posted above. Yes you can do that if you want to destroy or retire your engine earlierKidding aside, dapat 5K Km lang ang change oil if the car usage is mostly in Metro Manila regardless of car brand. The metro manila traffic condition is considered as "extreme driving condition". HTH
if your using petron trekker for a diesel engine, tapos VIC filters gamit mo... 5k is really the maximum at which you should change your oil,,,
*Petron trekker CI-4 has no available Material data sheet or any product information sheet regarding the contents of the oil
(personally i dont recommend this for personal vehicle use) there are a lot of better oils out there!!
*Vic filters are not good filters if you intend to prolong your engine like it just rolled out of your casa... there are also a lot of alternatives filters out there which is 200% better than VIC, examples(baldwin/fleetguard/purolators/bosch)
i suggest you read the REMOTE BYPASS OIL FILTRATION THREAD...
http://tsikot.com/forums/engine-fuel...tration-79219/
