Results 11 to 20 of 35
August 18th, 2005 04:30 PM #11
ang alam ko 30 seconds to 1 minute lang. pero kahit ako di ko sinusundan itong rule na ito..
mbt is right, kung cold start, buhos yung fuel. pero kung operating temp na, starting the engine will not consume an excessive amount of fuel.
September 2nd, 2005 04:58 PM #13
When is it better to keep the engine running as opposed to turning it off and then on? Minsan naka idle tayo sa traffic for 5-10 minutes, wouldn't it be better to turn off the engine? What negative effects would it have on the engine?
- Jun 2005
- 215
September 2nd, 2005 05:23 PM #14No adverse effect to your engine if you turn it off, specially if you are idling for that long. It actually saves you a lot of gas because you engine running with 0 mpg/kmpl. I do it all time specially if I get caught on a railroad track and the train have more than 3 engine pulling the train because it means that it long wait. But if you are in our native land or somewhere hot/humid, you have to suffer from heat/sweat.
September 2nd, 2005 05:33 PM #15
AFAIK, it's always ideal to keep frequent engine starts to a minimum, as engine parts are subjected to accelerated wear every time the ignition is turned on. On the other hand, you have the argument that idling the engine for too long wastes fuel.
It's one of those instances best left to judgement calls.Last edited by Bogeyman; September 2nd, 2005 at 05:41 PM.
September 2nd, 2005 05:43 PM #16Originally Posted by Bogeyman
lagi kasi kami nakaidle, waiting for kids, traffic, etc.
but now that fuel costs look like they're going to keep going up, it's time to rethink that...
September 2nd, 2005 05:48 PM #17
i rather keep it on.
madalas sa mga alternative route na lang ako kesa naka-stop ako sa kalyeng matrapik.
ex. kapag matrapik ang ortigas dun ako sa shaw or pioneer dumadaan.
September 2nd, 2005 06:01 PM #19
i'd rather keep in on specially at night time. mahirap na baka may gago na mang-holdap, at least pag naka on pwede na akong umarangkada agad hehehehe
September 2nd, 2005 07:02 PM #20Originally Posted by dx8976
Diesel engines, by nature, are less prone to suffer internal wear than gasoline engines because of two things:
1. Diesel engines are built to withstand higher levels of stress, since they require a high compression ratio to ignite the air/fuel mixture.
2. Diesel fuel is sprayed into the engine during the combustion cycle, which lubricates the cylinder walls, thus reducing friction.
Not sure if it has any impact on turbo, though.
