Results 1 to 10 of 15
    Do note it's a 4 page article.
    mineral oil vs Synthetic oil is talked about
    The "Idling Rule" with Turbo-Charged Cars | Team-BHP
    Apr 2012
    i agree, no need for excessive idling. i'm in the same opinion also that you should idle your car yourself and no need of a turbo timer.
    i agree, no need for excessive idling. i'm in the same opinion also that you should idle your car yourself and no need a turbo timer.
    whats your take on mineral oil and oil "coking"?
    Apr 2012
    i think if you follow the recommended oil change interval (for mineral/f. synthetic) then you are in the safe side.
    Oct 2017
    Stick to synthetic if your car is turbocharged.
    Also, avoid changing oil brands and types. Stick to one formulation.
    IIRC, i only changed brands once, from motul to redline. And i plan to use redline na from now on.
    good switch bro. the french oil umm.. i can't bash publicly 😅
    I use the same synthetic oil for my Fiesta Ecoboost and Forester XT.
    With regards to idling, during cold start-ups, I make sure the engine reaches nominal temperature before rolling out. Ford and Subaru uses different indicators to tell you so but Subaru has a boost pressure gauge which Ford does not offer on either Fiesta or Focus.
    Apr 2012
    OT: i started with casa oil for the 1st and 2nd PMS, then switched to RP Oil and used for a bit long, then i tried Delo for a while, switched to Motul CRDI, and now settled with Zix Performance supplied oil so far so good, no issues related to oil used. btw, where to find Redline? Autotech ba? masubukan nga din...
The "Idling Rule" with Turbo-Charged Vehicles
