Results 11 to 18 of 18
June 28th, 2004 06:54 PM #11
Yup, some Japanese brands also use C3 suffix, while others use different letters. But the brands you mentioned uses C3 suffix.
- May 2004
- 36
July 2nd, 2004 01:20 AM #12I checked the replaced bearing ... 6203LU. I'll have to DIY the replacement come the time, with a -C3. Thanks for all the help.
July 2nd, 2004 07:16 PM #13
6203 LU, that's NTN designation for 6203-RS1/ QE6, single sided rubber shield. QE6 is standard electronic motor quality, quiet running. :D
- May 2004
- 36
July 5th, 2004 02:10 PM #14Done changing it. Learned another thing too ... i need to loosen the nut holding the pulley before i could adjust the tension bolt. Btw, the replacement bearing used by the case was also a -C3 ... not bad, it lasted 3 years.
Thanks again guys!
- May 2004
- 36
July 5th, 2004 09:30 PM #15pahabol pala ... When you have alreaby inserted the bearing in the pulley, which side faces the engine block? the side where the bearing was inserted of the other side?
July 5th, 2004 09:40 PM #16
What do you mean which side?
Open side bearing should always be placed inside, while the covered side is on exterior to protect from dust ang other particles.
- May 2004
- 36
- May 2004
- 36
Xiaomi E-Car
