Results 21 to 29 of 29
March 31st, 2006 10:58 PM #21
[quote]it depends kung ano ride mo. sa akin yung idle up is below the carb (toyota corolla 12 valve). may screw yun which you can turn to set the idle up. dun sa diesel ko naman (mazda b22), may screw rin na ia-adjust. its located at the driver side, beside the engine block at the back of the the fuel injection pump.[/pump]
idle up setting is totally independent from the idle setting ryt?say your idle hovers at 750-800 on A/C off,when you switch the A/C on, idle up kix in and ups the idle at 900 or 1100? already adjusted the A/F setting pero ayaw tlga umakyat ng mataas idle ko.
Toyota is my choice
- Aug 2005
- 2,063
March 31st, 2006 11:40 PM #22Hehehe.. nice thread.. isa din ako sa mga praning and paraniod sa idle.. hehe.. bro alam nyo easy lng yan.. yung screw at the back ng carb dalawa yun isa sa air and fuel (sa ta-as )mixture and isa yung sa idle ng engine (sa baba) tama ba me?.. pwde lng yan DIY at may ma learn kpa.. mas maganda mag change ng idle kpag mainit yung engine or nka warm up na kasi yung ang saktong idle time..
regarding sa A/F mixture wla talaga akong alam dyan.. pero inikot ko nlang prang feel ko na tama na yun pra sa idle ko..
sa engine IDLE sakin kapag may aircon 700 RPM kasi kpag mababa nman hindi malamig yung aircon like hindi kumagat sa 'minor' .. tanong ko lng po ano ba talaga tamang IDLE kpag Aircon off and aircon ON?
- Jun 2005
- 164
April 26th, 2006 04:00 PM #23After nung last na check up ng kotse ko, minsan rough yung idling. may ibang araw naman na tama lang. bakit kaya ganun? parang mas maiintindihan ko kung consistently mababa, pero hindi ko maintindihan kung bakit within isang araw, paiba-iba yung idling. (constant naman yung aircon settings ko...)
thanks
April 26th, 2006 04:35 PM #24
[QUOTE=dj_ryankilmore]
kung ayaw umakyat then baka may problem yung vacuum mo at idle-up mechanism as what sir afrasay mentioned. ipa-check mo na lang sa mekaniko mo.
April 26th, 2006 04:40 PM #25Originally Posted by jarx
November 25th, 2006 03:11 PM #26
bro's, sa Lancer gli .. san b adjustment ng aricon? mababa rin kc yung idling ko pag naka-aircon
November 26th, 2006 07:43 PM #28
- Feb 2005
- 2
December 3rd, 2006 05:40 AM #29
Xiaomi E-Car
