Results 1 to 6 of 6
- Oct 2007
- 1
October 29th, 2007 10:03 PM #1Hi guys!
i'm very excited in joining TSIKOT,I'm planning to get a new car and i find it difficult in choosing w/ so many models in the market today,but my problem as of now is my old 94 civic esi in w/c i think needs an engine change,the problem is that its been a month that i have not used it due to overheating,it"s like when i use it in the morning it starts in one click then when i use it for a short drive it has no signs of overheating,but when I turn off the engine and start it again then thats the time my engine temp rise then overheats.Now here comes the real problem after 1month of not using it when i start the engine water comes spilling out of my exhaust pipe and you have to refill the water reserve asap,Now can i ask for an advice?do i have to change the engine or have it repaired?can you refer someone who's good in repairing it or sells a 2nd hand engine in good cond.and can also install it as well,I hope you could help
me.Thanks,more power and God Bless.
October 29th, 2007 10:11 PM #2
Welcome po to Tsikot.com!
You can also post your car problems here:
http://tsikot.yehey.com/forums/forumdisplay.php?f=8
Enjoy your stayLast edited by Memphis Raines; October 29th, 2007 at 10:19 PM.
October 29th, 2007 11:58 PM #3
welcome to tsikot mutz, i renamed and moved your thread sa "the workshop" para alam ng ibang readers kung tungkol saan ang post mo
October 30th, 2007 09:02 AM #5
did u check ur oil? is water mixing with the motor oil?
sounds like a cylinder head problem... maybe just the cyl head gasket
no need to change engine.
Tsikot Member Rank 5
- Nov 2003
- 3,848
October 30th, 2007 10:46 PM #6seems like a head.
depending on the problems, in some cases replacing the engine is a better idea than overhauling it. cheaper too minsan.
agree. ilang beses ko din pinlitmag-motor daughter ko. kaso ayaw talaga.
Recommended Parking Near De La Salle (Taft)
