Page 1 of 2 12 LastLast
Results 1 to 20 of 96
    Mar 2013
    Hi! Super newbie here so wanted to ask, I have a 2013 ford focus 2.0 and I wanted to do an oil change outside of casa. Gusto ko sana is an oil change outside once a year and casa pms once a year.
    Anyway, I checked the manual and it says 5w30 ang oil spec. I noticed tho that my casa has been putting in 5w40 shell fully synthetic for the last couple of years.did a bit of research and I guess it "should" be ok, given that it might be better for our outside Temps. So anyway, checked out a service station near us, super miler, and they offer oil change using caltex havoline pro ds fully synthetic oil, 5w30.
    My question is, ok lang ba change oil to havoline fs 5w30, then casa in 6 months where I'll assume they'll put shell fs 5w40, then 5w30 again after 6 months?
    Also, is it better to stick to oem oil filter (about douvle the price of they procure) or is it ok to use the brand they're using (bosch, I'm assuming the non premium version).
    Thank you for the help!
    Just have the oil change done outside casa and use 5w30 fully synthetic oil. You can buy online to save a bit further.
    If you live in the south metro area, bring your car to FordMaz in Parañaque or Las Pinas. They have the oils and filters you need. If in the north, go to Powertorq.
    Mar 2013
    Hi thanks for the reply.
    Is it alright though if the oil changes from w30 to w40 and then back every 6 or so months?
    Edit:I just read through the havoline spec sheet at it says its not recommended for acea spec oil engines, which what the focus engine specifies on the manual. I suppose that means I have to get the shell helix 5w40 anyway.
    Quote Originally Posted by sabaw View Post
    either viscosity is ok. w30 will result to better fuel economy. every6months padin though.
    use the correct diesel engine oil. do not use gasoline engine oils as they dont have the right diesel additives.
    He didn’t say if it’s a diesel. The Focus 2013 models came in 2.0L and 1.6L NA gas engines with DCT.
    Mar 2013
    Sorry hi yeah its the gasoline one.
    Looking through the specs required by the manual, only 2 oils so far ive seen have what it needs (ACEA a5/b5)
    Mobil 1 5w-30 (saw some sellers online)
    Amsoil OE 5w-30 (online sellers as well)
    So im deciding between these two
    Ive also seen/know these oils are good
    Royal Purple 5w-30 (a well known talyer in san juan sells this as part of the package)
    Shell Helix HX8 5w-30 (asked in a shell service station and this was recommended, they had the helix ultra 0w-40 but i dunno if thats good as its even farther from the manual spec)
    Motorcraft 5w-30 (seems to be a fan favorite on both local focus FB groups and online oil forums)
    Of all of these the motorcraft 5w30 is the cheapest at 380 a liter in banawe, and ive seen good comments about it though it does not specifically state ACEA A5/B5 (though it is "ford recommended" and essentialy a ford brand)
    Helix and royal purple are both good brands im sure but not ACEA A5/B5 (well not specified for RP and i think the helix is A3/B3)
    So weve got M1 and Amsoil OE. Amsoil being cheap at around 400-450/L online, and M1 having an "ok" price for a "premium" brand at 600/L. My biggest contetion of course is that im buying em online, so while i do belive there shouldnt be any problems, theres just that little scratch at the back of your head, though the M1 seller does have the verification QR codes on the bottles which you can scan to see if the bottle is authentic.
    Thoughts?
    May pic ba nung bottle ng Motorcraft 5w30 fully synthetic oil? I have used Motorcraft before on my Fiesta and FXT. Oks naman sya.
    Aug 2008
    Is the Petron HTP (High Temp Protection) Fully Synthetic range any good? They have Rev X HTP 5w40 diesel oil (~P450/L) and Blaze Racing HTP 0w40 gasoline engine oil (~P602/L). Their oils are supposedly made from PAO (polyalphaolefin) Grp IV base oil, same as Mobil 1.
    Quote Originally Posted by diehard View Post
    as long as it meets your engine requires. no engine spec ever required PAO.
    Aug 2008
    I’m trying out Petron Rev X HTP on my Kia Carnival hoping for better protection for the turbo during long provincial drives. That plus I prefer to buy motor oil from LazMall accredited vendors in Lazada to ensure the product I buy is genuine...dami fake sa Lazada.
    On a side note, how come Shell diesel oils are only rated CF, even their TOTL Ultra 5w40? They are ACEA A3/B3 A3/B4 compliant but only API CF rated.
    there are two kinds of oils.. diesel engine oils and gas specific oils..
    I did it with my Fiesta - changing oil every 10k km or around 12 months for 2 cycles. No difference at all during the time I changed oil every 6 months.
    Our Jetta is following a 15k km or 12-month change oil cycle, as prescribed by casa. Diesel pa yan ha. No issues at all for 3 years of use.
    ako yung lumang kotse eh mix viscosities ginagawa ko. KAsi yung mga iba pa kotse halos 3.5 lang capacity so yun naiipon eh ihahahlo ko sa oil change ng old cars namin. So walang nasayang lahat gamit.
    So 5w30+10w40 naghahalo.
    Next mag 5w40 ako.
    on a from time to time basis probably this is has no adverse effects. important mas lang ay regular oil changes at nakasulat sa manual ay advisable na viscosity for your specific engine
    Jan 2016
    Wala kasing 5w20, mas common ang 5w30, 0w20 naman sobrang mahal. 5w30 ako sa 2013 Civic ko.
    Aug 2008
    Sa init sa atin, I'll stick to the thickest viscosity(and highest W) na recommended sa manual.
    Sent from my SM-A125F using Tsikot Forums mobile app
    Quote Originally Posted by jigeloh View Post
    back in the day, when engine blocks were made of iron,
    the best oil was the walang-kamatayang SAE40 or 50.
    laluna kung pinaghaluan nang pertua!
    highs. the good old days...
    Jan 2008
    Meron naman naka indicate sa manual yung temp range na dapat gamitin na oil viscosity..
    Modern engine mas tight ang tolerances.. kaya mas ok yung thinner oil.. 5w30 na for me yung swak sa fuel efficiency at protection sa heat sa atin.. may mga bansa pa nga na mas mainit.. katamtaman pa lang here.. ang kalaban talaga sa atin ay traffic at long idling
    Feb 2012
    The reason I asked is I've read several owner's manual and for the newer gen engines recommended viscosities are 0w20 or 5w20.
    So I did a quick search with our online shops and they're now quite readily available and more importantly, very much affordable.
    Used to be talaga na either walang mga 0 and/or 20 weight oils dito sa atin. There was a time ang popular pa nga is 20w50.
    I do remember with my 9th gen the recommendation is 5w30, but during that time it was something quite rare thus the use of 5w40.
    With the newer generation, manual says 0w20/ 5w20 pero again probably just 3 years ago rarepaps pa dito ang said viscosities.
    As mentioned, today they are quite aplenty from the respectable brands, and with prices very competitive with the popular viscosities.
    Mamili ka between OEM's like Ford (Motorcraft), Mitsubishi, Honda, Hyundai, Suzuki, or manufacturers like Aisin, ACDelco, Idemitsu, Mobil 1, etc.
    IIRC 30 weight oil is only good for up to 30°C. I try not to use anything lower than 40 weight for my cars.
    Source: Rymax Lubricants Holland
    Also with our climate the "W" rating doesn't matter at all. It represents the oil flow at 0°F (-17.9°C).
    If SAE 30 is good for 5°C to 30°C, 5W30 extends the lower operating range to -35°C. It's irrelevant to us.
    That chart though is quite an eye opener, though I may still not be using 40 weight on my 10th gen.
    It spelled for us in an easy to digest way the usage of these various viscosities, either monograde or multigrade.
    I may probably stick with 5w30 going forward. It's only a 0.5~0.7% gain in efficiency with the thinner oils.
    Jan 2016
    Quote Originally Posted by gearhead000 View Post
    How much is the cheapest 0w20 you found?
Is it ok to have changing oil viscosities?
