Page 1 of 3 123 LastLast
Results 1 to 20 of 41
    If we compare the durability of the old school diesel injectors with the CRDI
    injectors like the D4D, DID, do we find them similar?
    My old 1992 L200 is still running strong this 17 years with only one time replacement of nozzles after 10 years.
    I just wonder how long these modern CRDI injectors last.
    It would be good to hear from those who got the first vehicles with crdi when these arrived in our Philippine shores.
    Tatagal din but shorter than those mechanical type.
    Sa CRDi fuel system, critical ang injectors they have a big and demanding responsiblity.
    Above normal temperature and compression may expand the tips of the injector from what i see dito sa shop.
    Central Diesel 4113711 to 13
    TUBIG and fuel impurities are the main kalaban ng CRDI system. Really makes you think of our fuel quality where lack of legislative standards make it of low quality compare to international and even neighboring countries.
    And because of the high pressure system, it may not last as long as the mechanical types.
    All has been well said by both gentlemen above
    Just to add as per experience. Our family has 2 units of a modern crdi engine. They are of the same age (2 and 1/2 years). Each unit gets its fuel from different gas stations. The first unit has very corroded injectors and have been replaced by the dealer. The other one still fairs better to this day.
    Water is indeed an injector's worst enemy.
    Aug 2005
    thats not very reassuring. Konti na lang pala di na covered ng warranty injectors mo sir. May we know anong unit ung maaga nag corrode injectors?
    and to think may water separator ang fuel filters di ba? Ibig sabihin hindi siya ganuon ka effective?
    Ask kung saan gas station ang may corroded injectors.
    Oem will only honor factory defect and not failure due to corrosion.
    Aug 2004
    Di yata sa unit... more likely sa fuel station mismo.
    Take this as an example... maraming horror stories from certain areas regarding Toyota fuel pump failures... but I personally know four or five D4D owners at or around 100,000 kilometers with no problems.
    I've never had problems with test units... ever... but I filled up once at a provincial station that I'd never used before and got one test unit into limp mode, from water contamination.
    It's all about your local stations. Nakakainis lang, nobody is enforcing fuel quality standards here. Heck, even the gasoline in some brand-name stations is suspect!
    Aug 2005
    so even if water contamination from the fuel per se is the culprit, does that mean the water separator function of the fuel filter is not up to the job?
    Quote Originally Posted by rst619 View Post
    Unit is a 2006 Innova. Water separator's effectiveness in this case? I really don't know. Here's some good reference about diesel fuel filters:
    http://www.filtercouncil.org/techdat...dieselfuel.htm
    The last part is especially interesting. It's about alcohol based additives.
    Aug 2004
    Too much water = clogged water separator = clogged filter = fuel pump burnout / possible fuel injector starvation = big repair bills, either way.
    It will depend on how much moisture is present in the fuel, gas stations and brands vary.
    Also a factor is the amount of flow that a filter is subjected and the saturation point of the element.
    Quote Originally Posted by 4JGtootsie View Post
    I drain my fuel filter every month. In my experience, marami pa ding tubig ang nasasala. I used to pump my petrol in Petron SLEX. The water causes sometimes hard starting. So kahit na dun sa bagong stations, meyron pa din water. Opinion ko lang naman. D4D 2.5 pala engine ko.
    Quote Originally Posted by bongliza View Post
    Petron diesel additive might be of help to control/contain and wash away sludge that might form in the tank filter and pump.
    We have first hand experience on what happens inside the HP3 when contamination occurs. Actually we remanufacture and calibrate them and offer them for exchange.
    Aug 2005
    Before, I thought kailangan mo antayin umilaw ung warning light ng fuel filter bago mo i drain. After reading this thread, I decided to have the CASA drain it for me at my 15000 PMS. Nothing came out, not even a tiny drop. Now, my question is, Am I that lucky, or is my fuel filter not that good.
    I live in Malabon BTW. Pero I gas up regularly on 1 station that is not prone to flooding tho.
    That is a good sign.
    But you dont have to wait for PMS, once a week or twice a month. Parang gripo lang yon sa ilalim ng filter.
    Drain gas tank once a year.
    We once we had a 08 strada with 4k sa odo, rejected warranty by mitsubishi. We were able to help the customer with a fraction of the price of a new HP3pump and 4 electronic injectors.
    Aug 2005
    Thanks a lot po
    Aug 2004
    How much for the injectors? Just for reference. ;)
    And... they rejected the warranty at just 4k? What the hell for?
    Injectors were ok, we repaired the HP3pump.
    Nag break-in sa Isabela nag pa carga sa isang gas station..... seguro mataas water content.
    Long drive, highspeed and high levels of water in fuel equals disaster.
    We were able to save him lots of money from the cost of a new pump and 4 injectors as recommended by Mitsubishi.
    getz crdi fuel injector may leak. 10,900kms palang. is this normal ? could this be repaired or replace na? damage?
    Quote Originally Posted by dieselNUBI View Post
    That is not normal.
    where does the leak come from? From the high pressure fuel line? or the return pipe to the pump? or down the nozzles?
    How was the checking of the leak done? and where is the leak seen?
    If the damage is just a loose high pressure pipe then i'm sure it shouldn't be "repaired" a handy open wrench might do your trick. but when the injector parts are failing, it should be brought to the shop/casa.
    Regards,
    ISO4113
How long does a crdi injectors last?
