Results 1 to 10 of 12
January 24th, 2007 01:48 PM #1
Is There A Possible Way To Increase The Horsepower Of Pajero 2.5 Tdic. How About The Claim Of Installing A Racing Filter Like K&n
January 25th, 2007 01:07 AM #2
try putting in k n n filter or an open type filter to lrt the engine breath easier, you can do the manifold add washer modification.washers and bolts land,dagdag power na.
March 1st, 2007 09:10 AM #3
hi.. yes it is possible to increase it. i did the washer mods and changed my air filter.. by doing so, you increase your turbo's boost at least 3psi. planning to install a blow off also...
- Sep 2006
- 84
March 2nd, 2007 09:14 AM #4Sorry for my ignorance what is manifold bolt and washer modification and how can this be done?
March 5th, 2007 07:17 AM #5
its just an ordinary washer to adjust your wastegate.. but they cleaned pa my intercooler and pipes.. you can call me at 850 8354.. luk for robert
March 5th, 2007 02:34 PM #6
madali din lang linisin intercooler. just take it off the engine bay, remove the piping and the fan/intercooler bracket, and spray some degreaser on it. i did it last weekend and it felt better.
i still need to have the pipings replaced, it collapses under heavy throttle kaya nagiging negative boost ko.
to the mods, pwede po pa-change ng topic title to something more descriptive of the actual thread?
- Jun 2007
- 207
August 17th, 2007 06:45 PM #7sir,
how about trying our system water/meth injection ..medyo mahal lng pero mas low maintenance k sa nitrous,works on load sensing ,,it does not inject the mixture unless it reaches a certain boost settings,,weve been testing it and madami nang satisfied turbo diesel owners sa power na binibigay na power ,depending on the mixture,,dyno tested and made in the usa..and ginagamit din sa kanilang mga top diesel truck challengers..
August 18th, 2007 01:43 PM #8
Lytspid,
May distirbutor ka na sa Manila?
Usap tayo kung wala pa. Inquire pa lang.
- Jun 2007
- 207
August 18th, 2007 07:01 PM #9sir 4j,
ala pa kmi distributor dyan and as per order muna yun system namin kc mhirap mg stock ng system na di agad mabibili bwat turbo disel kc may iba ibang specs na dpat mg fir sa type ng makina..tpos bka ma kitaan pa ng interes sa mga taga customs ,hehehee...
August 18th, 2007 10:47 PM #10
I see. Balitaan mo kami on your progress. Sana pag EB ng Isuzu peeps magpapademo kami sa iyo, pag nasa Manila ka. Syempre imbetado maski hindi isuzu kung interested.
Naalala ko kasi product mo kasi always raining dito. Puna ko maganda takbo takbo ng makina. Seguro doon nila nakuha yung idea.
high idle RPM at engine start
