Results 21 to 40 of 42
    Jul 2011
    #21
    Quote Originally Posted by kentrials View Post
    I have this toyota corolla 96 XE
    my gas consumption now is 8.5 to 9 km per liter city driving kapag long drive i reach about 14 to 15 km per liter..
    I would like to improve my gas consumption in city driving.. masaya na aku if aabot ng 11 km per liter city drive..
    any suggestion?.. how to drive?.. parts to change? parts to be checked?
    na uubos ang salary ko sa gasolina lng
    sir, basic maintenance na lang, if ganyan nakukuha mo sa 2e engine mo, ang tipid na nyan.
    Sep 2009
    #22
    Avoid using your A/C. Pag-aralan mo ang mga traffic. Tama sila, mas ok na magdagdag ng 1-2KM sa route mo kesa 1HR ka naman nakababad sa traffic.
    Oct 2011
    #23
    yah maybe I should start with this..
    after reading all your replies I already feel lucky with my gas consumption 9km per liter.. city drive..
    If RETZ is right and it improves my gas consumption, I let you know
    Im bringing my car to the shop tomorow
    cge, balitaan mo kami sir.
    Sep 2009
    #24
    BTW ano727 anu sasakyan mo? ang baba nman ng gas ratio 5.5km per liter?..
    Mazda CX9. 3.7L V6 engine.
    Sep 2012
    #25
    Quote Originally Posted by ano727 View Post
    Masarap sarap yan para sa hi-way
    Jul 2013
    #26
    Once you've done the tune-up, spark plugs and etcetera, there's a little more you can do.
    1. Rolling Resistance: Assuming your tires are in decent condition (and if they're not, consider replacing them... you shouldn't keep tires for more than five or six years, even if they're not bald), inflate them beyond the door sticker pressure. For typical car tires, you will see massive reductions in rolling resistanceat up to 40 psi, after which, improvements drop off. 35 is a good midpoint. I've seen some service drivers use 45 psi in their car tires (truck tires are at around 50-60 psi standard). Only issue from doing this is it will hurt hijjus if you drive over rough roads all the time.
    2. Start-up: Don't idle your car in the morning.
    Repeat: DON'T IDLE YOUR CAR. Once you've checked your water and oil level, start the car, buckle in and adjust your mirrors and seat. The time you take to buckle in and get comfortable is all the time it takes for the oil to start circulating. Drive off as soon as possible.A cold car and carb use craploads of gas, so you might as well get a few kilometers out of them while the car is warming up.
    3. Pulse and glide: You don't need to use gas every single second the car is moving. If you're coming up on a stoplight and intersection, just use enough gas to get going, then coast down to your target speed. In steady moving traffic, this is difficult, and it will get people mad at you, but traffic is not steady moving. Do it properly and nobody will notice you're doing it.
    4. Brake less: Drive as if your brakes are dead. In other words, leave space enough so that if the guy in front of you brakes to a stop, you don't have to brake right away. Less stress pa. You won't be cursing and slamming on your brakes. This saves gas because you need gas to build up speed. If you use the brakes, you're scrubbing off all that speed you gained, and have wasted your gasoline investment.
    5. Anticipate. Plan: If you pass lights with timers or are familiar with the traffic lights in your area, anticipate when they'll turn red or green. If you can coast down to a light without using the brakes, getting there just as it turns green, good. If you can avoid a red light by speeding up a bit, do so. Wasting some gas for a little more speed is better than idling at the stoplight for the next two minutes. Also, you know that jeepneys stop. All the time. Don't follow them too closely. Plan your overtakes ahead of time so you'll use as little gas as possible overtaking. Remember, also, that too slow is also a waste of gas. Dawdling along at 20 km/h leads to terrible economy. You should get best economy at around 40 km/h in the city and around 70 km/h on the highway.
    Good luck!
    +1
    Pero kahit gaano ko i-follow yan.. wala ng itaas FC ko.
    Bro para sken ok na ung 9km/L city driving mo and 14-15 km/L long drive. Yung corolla 2E ko.. nasa 7+ km/L lang sa city driving. Swerte na umabot ng 8 :D. Pero always on naman A/C ko at paminsan minsan naghihintay while engine running.
    Apr 2012
    #27
    try driving slower than your normal speed. say you normally drive at 80km/hr, try lowering your speed at 60km/hr. be light footed sa gas pedal, less throttling means less gas consumption
    #28
    Personally, I've found that slower isn't more efficient. I try to get to 80 kph as much as I can when in the city, provided the traffic allows for it (this takes long since I accelerate very gently).
    Smart acceleration and braking is more important than speed per se (unless you're going really fast).
    Oct 2011
    #29
    parang hindi effective yan sir ah.
    Apr 2012
    #30
    try lang ni TS...if di effective then no harm done
    Sep 2006
    #31
    I drive hybrids and I've found the techniques pulse and glide and driving without brakes really help. Also I try to park facing forward when I can and run errands on the same day to minimize trips. We also use our hybrid with better MPGs more vs. the one with less MPGs.
    Aug 2012
    #32
    With my Haima7, driving conscious or unconscious doesn't really do much about my FC.. I am trying the 2000 RPM this full tank, and ayun, parang 8KM/L din ang kalalabasan. Eh before, I am shifting sa 2500RPM mark, parang wala namang pinagkaiba.
    #33
    idol, sa carb ata effective yan. kasi ganyan sentra ko po the slower (lower rpm) mas matipid sya. pero sa bagal mo parang di worth it yung 0.1~1kpl na additional.
    Dec 2009
    #34
    travel light (dont make your car a luggage)
    when approaching an inclined road (eg flyover, bridge) release the gas pedal right before you reach the crest. youll have enough momentum to go over it & still have enough assistance from gravity to coast along the declivity of the bridge
    dont run the car idle more than 3 minutes. if you have to wait for someone for more than 3 minutes, you are better of shutting the engine
    use thin oil so you wont have to idle that much after starting your engine from a cold state. but considering the age of your engine, it could be leaking oil already so using thin or less sticky oil could be more costly
    plan your jaunts well to minimize shutting of the engine in between trips. starting the engine gulps 3 minutes worth of gas running in idle mode
    always make it a point to park under the shade
    Jun 2013
    #35
    How does this affect gas consumption?
    Aug 2010
    #36
    Quote Originally Posted by vel0city View Post
    It doesn't. Unless somebody wants to BS me into thinking that shade = lower temperature = more dense fuels. Because it doesn't work.
    #37
    avoid traffic. avoid driving during the rush hour period.
    Dec 2009
    #38
    it helps you keep aircon usage sparingly
    #39
    increase torque.
    Dec 2007
    #40
    Good luck!
    Very sensible suggestions sir! I practice 2 and 5, then 3 and 4 to a certain degree. I'm very conscious with my fc and my almost 6 year old d4d innova at around 41K km odo still have the original aspec yokohama tires. Starting at about 35K km, i have noticed a 0.5kpl decrease in my fc. I think it's not due to those d4d issues (i'm hoping) since I haven't experienced any smoking, stalling or power loss. Would the tire issue cause this significant fc change or is there any other item I should look at?
How to improve my gas consumption..?
