Results 1 to 9 of 9
- Sep 2007
- 8
February 4th, 2009 04:41 AM #1Mga bossing, How would i know if my turbo is ok (working), How i would check it? My rig is pajero '91 Pls advise. THANKS! ~Natz
February 4th, 2009 08:53 AM #2
February 4th, 2009 09:24 AM #3
Turbo's will usually smoke when they about to go out... but not all the time.
When you drive you should be able to hear the whistle when the boost kicks in. If you're very careful, you can pull the boot off, and peak in at the turbine.You should also feel a surge in acceleration after the first 1000 RPM at hard acceleration.
- Sep 2007
- 8
February 4th, 2009 11:52 AM #4
February 4th, 2009 12:23 PM #5
hmmm i dont know if mitsubishi pajero has a in dash boost gauge. you can buy a after market gauge but you'll need to know whats the stock boost of your turbo, ex: a stock turbo on your car is 9psi and the gauge says you're only making 0 or 4psi surely you have a problem. then again if your force induction you should have one gauge so you know what is working or not. for you to try DIY may not be a good idea unless you have a friend who had eperience with turbos.
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 15th, 2009 11:39 AM #6if the acceleration hasn't changed over time it should still be working. don't remove the turbine na. sayang lang pagod mo.
February 15th, 2009 01:27 PM #7
boost gauge costs more or less 1k. you can hook it via boost compensator with a "T" extension hose. measure it while running full load on steep uphills not while parking...
February 16th, 2009 10:11 AM #8
- Sep 2007
- 215
February 16th, 2009 11:43 AM #9usually check for leaks ... kung nagbabawas ang oil usually dun galing
look at hoses ... try mo patakbuhin ng 100 ... kung may nginig before or at 100 sira na yung turbo mo ... try buying surplus 10k to 13k
if you have money to burn ... try installing a turbo timer to moniter your turbo
BANAWE AUTO SUPPLY
regy
7120115
Xiaomi E-Car
