Results 1 to 10 of 22
- Sep 2003
- 74
April 30th, 2008 07:23 PM #1Good day good Tsikoteers!
Where else can I go to for help with my car but here, so here goes....
I'm using a Honda Civic LXI bought in 1997. In 2004 and 2005, the temperature gauge would just continue to rise until it almost reaches the redline, then goes back down to midlevel after some time. There seemed to be no set pattern when this would happen. Sometimes it does while I'm driving, sometimes days would pass when my drive seems hassle free.
In both instances, the problem was traced to a worn out thermostat and thermostat valve, and these parts were replaced then.
Last Friday, it happened again, and I'm almost sure this time that the thermostat and thermostat valve are worn out again.
When the problem was being diagnosed and fixed previously, some people suggested to me that I would be better off having those two parts removed from the engine altogether.
Has anybody had the same problem with their civic and were successful in removing these parts? Share naman po sila ng experience nila.
Sir Speedyfix and others, your thoughts are highly appreciated.
Thank you very much in advance!!!
April 30th, 2008 08:09 PM #2
na check mo na ba rad fan baka mahina na ang takbo or barado na ang radiator mo pa overhaul mo na.
To test
if during high speed tumataas ang temp, and pag bumagal na takbo bumababa rin ang temp, try mo muna pa overhaul ang radiator mo and check thermostat.
if during low speed tumataas ang temp and sa high speed naman bumababa ang temperature, possible cause is rad fan.
wag kang magaalis ng parts like thermostat meron purpose ito kaya nilagay yan as per design, pinagaralan iyan bago ilagay sa kotse mo, wag kang maniniwala sa sabisabi. kailangan mong gawin ay ipaayos ang problema wag mag short cut.
- Apr 2008
- 3
April 30th, 2008 11:50 PM #3bossing ask ko na din kc ganyan din ang problema ko sa esi 93 ko..pag mabilis tumataas yung temp nya..bago radiator ko and thermo swith, meron din ako aux fan na plague naka on...ano kaya posibleng sira neto? napa ayos ko ndin yung head gasket nya..help naman po...
May 1st, 2008 12:58 AM #4
The purpose of thermostat is to get the engine up to maintain the optimal temp., w/o it can cause you too much gas since your car is lot cooler. Do not remove this into the cooling system.
You should find out the temperature of the thermostat that was originally installed in the car (ask your honda parts dealer)and stick with that and make sure to replace the the old coolant w/ fresh 50/50 coolant.
Tsikot Member Rank 2
- Sep 2006
- 1,335
May 1st, 2008 01:21 AM #5
- Sep 2006
- 1,335
- Apr 2008
- 3
May 1st, 2008 07:43 AM #7
May 1st, 2008 09:32 AM #8
Some tropical and desert countries mechanics sometimes remove the thermostat since the climate is already hot. The coolant flows better w/o constricting it and the hot climate helps bring the engine to peak temperature. Engine run efficiently when they are at thier proper operating temp., and again IT WILL NOT OVERHEAT the engine.
nurse on wheels
- Dec 2006
- 392
May 1st, 2008 09:43 AM #9^ i can attest to this based on my experience. my car didn't come with a thermostat (seven years ago, 2nd hand), never overheated. but yeah, the thermostat has a purpose, better to replace.
Tsikot Member Rank 4
- Jun 2006
- 2,605
May 1st, 2008 09:45 AM #10To check if you t-stat is ok:
1. Remove it and put it in a pail of water preferably with a thermometer. You can tie it to a wire or string or use tongs to pull it out.
2. Heat the water.
3. Watch the t-stat, it should open. Note the temp when it opens and check vs the rating marked on the t-stat body.
4. If it fails to open, replace it.
Note: Be sure the engine is cold before doing any work. If the t-stat is already open when you remove it, replace.
Macky,
Check if you have oil in your water/coolant.
Check you oil is it milky colored
Do you lose coolant?
Try replacing your radiator cap if you haven't done it yet, its cheap
Check your fan belts may be lose or damaged
do you hear boiling sounds
how does your exhaust smell
ask a mechanic to check your water pump
Weld preparation is poor. The WPS should have clearly specified what's to be done. Given that...
Chery returns to PH
