Results 11 to 20 of 25
December 10th, 2007 01:52 AM #11
yung getz ko po ganun din...
may sensor kasi sakin sa panel kapag malamig ang makina...pag may ganun nagiging mga 1500 rpm yung akin hanggang magsettle sa 800-900 idling nya.
February 17th, 2008 08:53 AM #12
sa gli bigbody nasa mga 1.5k lang. For how long should the Fast Idle Start ba lasts or does is it based on your engine temperature?
Tsikot Member Rank 5
- Nov 2003
- 3,848
- May 2010
- 6
May 8th, 2010 12:10 AM #14similar problem din po sakin pero ang pagkakaiba, ung idling ko e permanent na nasa around 1.3krpm. ok lang po ba un? dati po kasi 1krpm lang.
- Apr 2024
- 25
April 26th, 2024 01:55 PM #15
- Apr 2024
- 25
April 26th, 2024 01:59 PM #16In my car idle on coldstart was 2k high need 2 to3 mins to be restarted the engine to get the normal idle can anyone encountered same as my experience any idea what part to be replaced
- Apr 2024
- 25
April 26th, 2024 02:08 PM #17
- Apr 2024
- 25
April 26th, 2024 02:15 PM #18
- Jun 2011
- 1,235
April 27th, 2024 07:53 AM #19
- 54,212
April 28th, 2024 12:14 AM #20there's this youtube article, about a 2000s altis, that had a high rpm on cold start (2000+ daw), that only gradually went down to sub-1000...
sabi niya, may leak na raw ang intake manifold.
fixing it is the solution, daw.
our 2003 altis, had a high cold start rpm of only 1500...
Kapag tinuloy pa yan sigurado magtatagal dahil makikialam ang Taguig LGU.
Makati Subway. Completion date: 2025
