Results 11 to 13 of 13
- Jul 2010
- 570
July 7th, 2012 02:30 PM #11Baka mga Casa lang meron nito Leakdown Tester. Nag google na lang ako ako at gumawa akong sarili ko na Leakdown Tester. Hindi ko sure kung accurate pero compare ko na lang reading sa mga katabing cylinder ng engine ko.
Ito youtube video paggamit nito.
[ame="http://www.youtube.com/watch?v=WgrfT0LFMhc"]How To Perform A Leak Down Test - YouTube[/ame]
July 7th, 2012 04:43 PM #12
transforming your otherwise original car into a frankenstein is a maze of experimentation, frustration and headaches. it is very unwise to do this unless you have the time, money, know how and your own garage to do the transformation. mechanic A says this, mechanic B says this, mechanic C says this and so on. there's too much hunches, guesses and possibilities. diagnosis is needed and not the trial and error or, error and error approach. have your diagnoses translated into numbers:
compression: dry-first puff and four puffs , wet- first puff and four puffs, all in psi or kgm/cm2 or in bars of pressure
cylinder leakage test: how many percent leak each cylinder
simple and can be done right at your parking spot, oil level and type of oil
check your oil filler cap for evidence of sludging and check your pcv valve for free movement and spring function. that way, if you digitize your results, it is objective and not subjective evaluation.Last edited by jick.cejoco; July 7th, 2012 at 04:49 PM.
July 11th, 2012 12:10 AM #13
gud news mga paps kanina pinalitan ko ng spark plugs nawala usok dinala ko sa makai ok na ok spark plug lang pala ang culprit thanks fo all yhe adices mga tol
high idle RPM at engine start
