Results 1 to 6 of 6
- Nov 2011
- 25
January 20th, 2012 12:14 AM #1Help po mga bossing.
I just recently got a Foton blizzard pick up with 2.8L 4jb1 engine and currently experiencing vibrations and loud engine noise inside the cabin. Dealer said it's normal with the unit and I was wondering if Sound deadeners like Dynamat, Fatmat or Raamat can help me, if not eliminate, reduce them.
Has anyone tried these products? Need your expert opinion and feedbacks please
Thanks mga bossing. ^_^
January 20th, 2012 12:37 AM #2
Don't expect miracles but those products can help reduce noise levels. Especially when placed in the front floor area and transmission tunnel.
As for the vibrations, I think that's part of using an Isuzu-derived engine. It does smoothen up a bit once you rev it up.
- Jan 2008
- 4,726
January 20th, 2012 10:40 AM #3those are aimed to reduce vibrations especially sa door panels... you may improve your firewall and floor shielding by placing another layer of pressed foam..
- Nov 2011
- 25
January 20th, 2012 02:22 PM #4
- Nov 2011
- 25
- Nov 2011
- 25
January 20th, 2012 02:28 PM #6Mga bossing, What about engine & transmission mounts? If I change the stock mounts with quality mounts, will it lessen vibrations?
Tnx.
Better to buy the similar-era clone starex 4x4 (not sure lang if local or imported but original lhd...
Mitsubishi Philippines
