Results 1 to 20 of 22
    Nov 2015
    Thank you Dr. D! Medjo nag alala lang ako kasi kakagastos ko lang tas baka gastos nanaman dahil baka may masira makina sa pag oover start ng kapit bahay namen.
    Nov 2015
    So last weekend, I went to a AC (sa cainta, harap ng sta, Lucia sho is called PFE) shop to have my evaporator replaced since butas na daw, they replaced it with a laminated one, nireplaced na din ung expansion valve and dryer. Ok naman lumanig na, then kinabukasan (monday), nawala ung lamig. I went back to the AC shop for a back job, we found out that ung condenser pala ung butas. For me ok lang naman na palitan na ung evaporator since luma na talaga and bad condition na. So they replaced my condenser with a laminated one. They tested my compressor and ok pa naman.
    *Ung condenser sure ako may problema kasi tinest sa harap ko at may butas talaga.
    *They tested my compressor and walang leak at normal pa naman anf pag pump ng freon.
    *Ung evapoator hindi, kasi hindi nila tinest (ok lang kasi it looks bad na talaga).
    Nakaka asar lang kasi pinag bayad nila ulit ako ng freon kasi consumable daw. For dapat nakita na nila yun ung una pa lang.
    All in all it cost me 9k.
    Mga sirs question lang po, kasi pag check ko kanina sa compressor ko, basa sya. Is that normal sir? Hindi naman sya oil, basa lang talag ng water parang moisture from the freon (not sure)?
    Sana may makatulong sirs.
    Thanks again.
    Thanks again.
Help po pls. About my corolla 94 xe 2e engine
