Results 11 to 20 of 27
- Aug 2008
- 17
April 26th, 2013 03:16 PM #11mga sir, baka may mairerecommend po kayo na specialist sa carb? cavite area po. tnx
- Mar 2013
- 33
April 28th, 2013 08:28 AM #12
- Aug 2008
- 17
April 28th, 2013 10:36 PM #13
April 29th, 2013 12:33 AM #14
- Mar 2007
- 79
April 29th, 2013 08:58 AM #16
April 29th, 2013 10:26 AM #17
April 29th, 2013 04:36 PM #18
wd40 is totally different from carb cleaner. best way is to spray it while reving up the engine to remove the gas residues/dirt. kadalasan, tataas ang idle ng car mo after using it. just tweak it to return to normal idle. nasa 150 petot pataas ang carb cleaner.
- Nov 2014
- 1
November 2nd, 2014 11:18 AM #19Ganun din po problema ko ^_^
sir... kasi baguhan din lang po ako sa motor...
yong akin din is namamatay pag primera... gaya ng problems sa kanya,,,
ang pagkakaiba lang po is walang carborador ung Raider115 fi ko... computer box po kasi un...
ano po bang problema ng maipaayos ko po?
November 3rd, 2014 10:32 AM #20
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
