Results 11 to 20 of 21
- Oct 2005
- 72
October 19th, 2005 01:16 PM #11do you think iyon compensator/actuator or auxillary fan ang isa sa cause ? bakanagkakarga nang kulang na electric power ....
suggestion naman ????
October 19th, 2005 01:31 PM #12
So before freon recharge ok ang idling mo. After recharge fluctuating na. If I were you I'd go to another aircon shop and have my system checked. Maraming pwedeng reasons. Pwede dumikit ang condenser sa radiator. Pwede mahina ang aux fan. Pwedeng overpressure dahil nasobrahan sa freon. The servo should be the last resort dahil, yun nga, mahal sya.
- Oct 2005
- 72
October 19th, 2005 03:46 PM #13I guess you have a point .... anyway i'll see first elctrician to check the wiring system the i will ask them to check also the system of A/c.
Thanks appreciated.
- Oct 2005
- 72
October 19th, 2005 03:50 PM #14bro, I'm palnning to put in in casa sa dasma mitsubishi itong ride ko. do you think pagpinasok ko ito maayaso kaya nila mabut or maybe they will say to replace the servo tapos hindi naman pala pinalitan... baka kasi ganun.. because may that i heard
ganoon nangyayari sa casa. because we cannot see what happening inside and were not allowed to get in diba. only my opinion.
October 19th, 2005 03:59 PM #15
May list kami of Recommended Shops dun sa http://mitsulancer.proboards60.com/ . I'm sure may trusted shop malapit sa Imus. 30 minutes lang nakaapak sa casa tsikot ko. Freelance shops ako parati kasi at least nakikita ko habang ginagawa.
- Feb 2007
- 2
February 11th, 2007 08:35 AM #16have the same problem. eratic idling ng 1994 GLXi. punta ako mitsubishi mayroon silang computer analyzer lumabas servo problema. may chance ba mag kamali ito? mag kano na ba servo nayon?
February 11th, 2007 08:51 AM #17
guys sama ko na din.
yung auto ko kasi kapag cold start, ang taas ng idling mga 1200rpm
pero kapag uminit na or umandar na nagiging normal na sya (900-950rpm)
anu kaya problema nun?
February 11th, 2007 04:50 PM #18
anong tsikot mo? walang problema yan normal lang yan kung automatic choke siya.
February 11th, 2007 04:53 PM #19
97 gli corolla po :D thank you po
kasi before ndi naman ganun eh, nung nag change oil lang ako saka naging ganun
February 11th, 2007 04:59 PM #20
* tmc
Suggestion ko lang alamin mo muna rules and regulations nila about back job. Alamin mo kung maibabalik ba ang pera mo or may babayaran ka pa ba kung sakaling hindi yun ang sira.
O kaya man hingi ka ng opinion sa ibang shop.
high idle RPM at engine start
