Results 1 to 10 of 33
- Nov 2002
- 37
July 28th, 2003 12:08 PM #1Guys,
patulong naman...
I have 1993 mitsu lancer glxi... ang problema ang idling niya... on a regular idle, ok na ok siya... pero pag nag-on na ang aircon compressor, todo baba ang idle niya up to a point na namamatayan...
pinacheck ko at ang mga sinabi eh:
1. computer box
2. throtle vavle
3. idle up
4. servo kit
sabi nung dati kong officemates malamang idle up... sana tama siya kasi mura lang daw yun...
will send it sa mekanik this weekend... need your inputs naman.... tenks...
- Nov 2002
- 37
July 28th, 2003 02:47 PM #3artpogi,
ay ganun ba? kahit na ok naman ang minor niya pag walang aircon? pag may aircon compressor lang naman bumababa...
sabi din nga nung dati kong officemate usual problems daw ng lancer ang servo kit... yun din ang unang sagot niya...
may idea ka ba magkano ang servo kit for lancer 93?
July 28th, 2003 03:20 PM #4
very common prob ang servo kit sa lancer... i know at least 4 friends of mine with lancers that have changed theirs already.
July 28th, 2003 05:48 PM #5
saintluci,
AFAIK kahit okay ang menor mo kung naka-off ang AC, basta hindi normal and idle speed kapag naka AC ka, there's a possibility it's a servo kit problem.
Sorry I have no idea how much a servo kit for your car is. Normally kung brand new yan aabot ka ng around 10K.
tanong-tanong ka muna baka may mas mura pa.
HTH
- Nov 2002
- 37
July 29th, 2003 09:51 AM #6maraming salamat po sa mga comments ninyo...
ang mahal pala ng servo kit... yari ako nito...
- Mar 2003
- 70
July 30th, 2003 09:09 AM #7just a suggestion, you may want to try and have your fuel injector cleaned by casa.
ask mo muna how much. i don't think its expensive.
i've heard nga na lancer usually has problem with the servo kit.
i have a '93 corolla Gli before with the same problem. brought it to several repair shops, and most of them say idle-up, etc. replaced them but it didn't solve the problem.
dinala ko sa toyota, they said i only have to have the fuel injector cleaned. it worked, it only cost me only Php300.
but other toyota casa were also advising me to replace it.
i think the fuel injector of the corolla = servo kit of the lancer ,other casa refer to this as the servo kit din kasi. guys correct me if im wrong.
July 30th, 2003 11:40 AM #8
This I'm pretty sure, fuel injector is totally different sa servo kit.
Servo kit might be the same or equivalent as idle-up switch (or something) for other cars. Not too sure about this though
July 30th, 2003 12:02 PM #9
servo kit yan dude! sakit ng mga mitsu yan eh. just had mine recently replaced for 14k (casa price)
sayang, may nagsabi sakin na merong brand new OE servo kit sa banawe priced at 9k. forgot the name of the shop though.
if you want, you can check for the name of the shop sa clubmitsu forums under the galant message board. "7g idling problem" yung name ng thread.
HTH
- Nov 2002
- 37
July 30th, 2003 12:18 PM #10maraming maraming salamat talaga sa mga inputs ninyo... pagpunta ko sa mekanik at least alam ko na mga options ko...
sana huwag naman servo kit... la pa akong perang pampalit nun...
alas! for obvious reasons, they are sometimes the last available slots...
PH Gov't looking to bring back excise tax for...
