Results 31 to 33 of 33
November 20th, 2010 06:08 AM #31
same scenario's here..
Pero ang pinagkaiba ko naman ay pag naka on both headlight stock (60/55w) and A/C then rev from 900 it will drop to 500 then pag hinayaan molang..babalik siya sa 900 mga 5 secs. pero pag isa lang ang bukas either headlight or A/C walang problema yung idle ko.
ano kaya problema nun?
does cleaning my throttle body and whole intake will solve this problem?
or do i need to replace my alternator or IACV?
(have my alternator checked sa electrician using digital meter) - normal naman raw yung reading ng alternator with and without load.
any inputs would be greatly appreciated.
Ride: Civic vti M/T 2000...
- Jul 2003
- 12
December 31st, 2010 04:03 PM #32I had rough idle with my 2003 CRV AT, with hesitation especially when the aircon is on, even after cleaning the K&N drop-in filter. After throttle body cleaning at Speedyfix, it is now solved. My friend also suggested that if the throttle body cleaning doesn't solve the rough idle, it could be the IACV, the fuel injectors which need cleaning, or bad spark plugs/wires. If these do not solve the problem (in this order), then it could be much worse.
- Jan 2011
- 1
January 11th, 2011 06:07 PM #33mga sir.. ask ko lng.. i have acquired a '94 corolla gli matic.. tpos napansin ng dad ng gf ko that the idling is noisy daw and ipacheck ko.. what could be a reason para mging maingay ung idling? as far as rpm nman kc, all seems fine.. although pag nka-idle ako tpos nasa D ung shifter, mejo manginig ung engine..pag nkaneutral smooth naman.. any inputs po?
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
