Results 1 to 6 of 6
- Feb 2007
- 4
November 10th, 2008 03:09 PM #1Good afternoon mga sirs. I'm new here sa tsikot and I just want to ask, kapag nanginginig po yung car(w/c is an A/T) lalo na sa mga low gears, ano po kaya yung problem? kasi yung honda IDSi na naddrive ko e ganon.
what do you think are the causes for this one? Fuel filter kaya o atf? and what are the signs that I need to change atf and fuel filter?
November 10th, 2008 03:12 PM #2
nanginginig, most probably sa fuel filter or sa fuel lines.
fuel filter should be regularly changed (kasama sya sa PMS) every 10k kms. ATF, i think should be changed every 20k kms.
- Feb 2007
- 4
November 10th, 2008 03:29 PM #3Thanks sa reply 1D4LV, pero ask ko lang ulit, saang part ba ng City yung fuel filter? kasi a friend of mine who works at Honda told me that they have a special tool for removing it and at the same time e sa may shift knob daw tinatanggal yung filter. Is this true? kasi kung ganon e Honda Service Centers lang yung makakatanggal nun.
November 10th, 2008 05:59 PM #4
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 16th, 2008 12:01 PM #5replace the cvt fluid. be sure not to use atf or masisira transmission mo.
it's b.s. na casa lang makakapalit ng fuel filter ng city/jazz... we just replaced one last week without any problems.
the gas tank of the city/jazz is under the car and almost in the middle. remove the shifter, handbrake and some panels and you can access it na.
- Dec 2017
- 16
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
