Results 1 to 10 of 16
July 23rd, 2016 12:51 AM #1
lately sometimes but not always kapag galing po sa complete stop such as traffic or stop light kapag pasok mo ng 1st gear at tatakbo na biglang kakadyot-kadyot ang makina as in shaking heavily parang magkakalasan.may times na ok tapos biglang ganyan. ano po kaya cause nito?
- 54,205
- Nov 2008
- 641
July 23rd, 2016 03:21 PM #4
July 25th, 2016 01:44 PM #6
fuel filter and pump has not been checked, engine support visually ok naman. does the quality of fuel something to do with it? or spark plug maybe?
July 28th, 2016 08:55 PM #8
800-900 rpm. no misfires. anyways based on one mechanic he said clutch disk daw its slipping daw. pero kapapalit lang ng clutch nito wala pa nga 3 months. dapat daw kasi orig ang pinalit. replacement kasi pinalit ko. yun nga kaya po ang dahilan?
July 29th, 2016 05:51 AM #9
If the symptoms only appeared after the clutch replacement, the most likely cause of the jerking upon take off would be poor friction surface preparation prior to clutch reassembly. The new pressure plate was coated with oil based corossion inhibitor and was not cleaned with a non petroleum based cleaner such as brake parts cleaner or carb cleaner. Or the flywheel surface had oil residue, or the "mechanic's" hands were too dirty and he touched the friction surfaces with them. Your frictions may be slipping from contaminants.
July 29th, 2016 08:49 AM #10
so you mean sir need i pull down na naman ang transmission to have it cleaned?
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
