Results 11 to 20 of 56
- 52,698
September 4th, 2015 07:54 PM #11- - - - - - - - - - - - - - - - - - - - - -
no offense meant, but honestly, i do not know what the guy who said it, really meant.
very loosely, it can mean "there's something wrong with the engine", or, literally, the engine is making strange knocking sounds.. and we all know that can mean so many things to so many people to so many engines..
it can mean something as minor as pre-ignition brought about by mal-adjusted ignition timing or engine overheating, or a broken valve ice-picking its way thru the engine block or head..
September 4th, 2015 08:05 PM #12
Sir miko101130, naibaba na po ang makina at dinala ko na nga sa machine shop and they gave me nga a job quotation which i already attached. If you will analyze the job quotation, you will note the parts to be replaced and also the parts which will need to be machined. Based on that, you can also surmise/conclude the extent of the damage. Hindi po ako maalam sa mechanical engines, but i know that most car enthusiasts can understand and analyze the attached job quotation and form an opinion based on it. Hopefully, you can, too...
September 4th, 2015 08:10 PM #13
- Jul 2009
- 3,604
September 4th, 2015 08:31 PM #15
Sir mda, bakit po sa Toyota? To get the maximum possible charge? Or to get the list of items to be bought & repaired (sort of a baseline to compare with others)? Mahal po kasi ang charge nila just for the estimate, and mabagal po sila kumilos kasi...
September 4th, 2015 08:43 PM #16
Sir dr. d, i think it is obvious naman po when "kumatok ang engine" is mentioned in the same paragraph as "the dashboard indicator light for the oil lit up", that more-or-less alam nyo na po kung anong nangyari... I am looking for some help po and do not need people to nitpick my post. i believe i have posted a lot of info already on my problem and hopefully you guys can sift through it to get a good idea as to the extent of damage on our engine. Ayaw ko po makipag pilosopohan sa inyo dahil ang kailangan ko po ay ang tulong ninyo in terms of suggestions as to where to go or what to do, etc.
- Jul 2009
- 3,604
September 4th, 2015 08:56 PM #17In my opinion sir, it is for these things:
1. The 'casa' has the technology and expertise to check. They may not have the street smart of the local talyer, but they will have a checklist of what to check for problems like this that talyers may miss when they don't notice the symptoms. This is especially important if you yourself are not a car expert. This will at least provide you with a list of items to be bought and repaired as you mentioned.
2. To get the maximum possible charge... and to add, for example if all local talyers will charge me 50k and the casa 55k for what appears to be a MAJOR ENGINE REPAIR, I will go with the casa everytime. This is an exaggerated scenario where the values are very very close together, but you get my point.
3. I don't mind a high charge for the estimate, as this is my car engine I am talking about. The car is about worthless without an engine that runs reliably. If you expect to spend 30k for an engine, an additional 1-2k to diagnose it WELL is not bad.
4. Never really found the Casa slow... when was the last time you visited the casa for major repair? Hehe
If you're going to repair something as critical as your car engine, you might as well do it right diba? Hindi na bali hindi muna magamit for a while...Last edited by mda; September 4th, 2015 at 08:59 PM.
September 4th, 2015 09:30 PM #18
How about getting a second opinion sir. Try nyo po ito domeng (0916) 331 7722 he does home service just schedule with him. He will overhaul your engine kahit sa house nyo basta may space kayo and you will see everything being done to your engine and also the parts that goes into it. Highly recommend him. Former saudi mechanic. Honest guy. Hope this helps sir ty
September 4th, 2015 10:01 PM #19
September 4th, 2015 10:08 PM #20
Sir SkyFlakes88, thank you po for your suggestion! Does he have his own shop? Although it would be cheaper to have things done here at home, I would prefer that the overhauling be done at the mechanic's shop.
Yung sa full record documentation nyo po, sa service manual ng CASA nyo po ba nirerecord self PMS...
Suzuki JIMNY [merged threads]
