Teka, tick lang ba? Walang redondo? Kung malakas pa yung ilaw saka busina, you can exclude the battery as the culprit.
Wala bang alarm yung kotse mo? Kasi, baka rin na-activate yung starter kill.
tama si valvura. have your batt checked 1st. pa-charge mo if needed. kapag nag start, the electrician will be able to determine if your battery is charging. pag di na kumakarga yung batt, you might have an alternator problem.
maari din loose battery connector ,nakita mo ba kung may " muta " yun mga poles ng battery mo ?
try removing the battery pole clamps and re-attach them (minsan kasi kahit mahigpit ang battery poles eh hindi dumadaloy ng maayos ang current)
... if still no avail, possible your battery is nearing its life span and needs replacement,
last possible cause is the starter itself, it may need to change its carbon contacts or the solenoid, but replace the carbon brush first prior changing the solenoid... the solenoid also depends from the carbon brush..
Mga guru's, Tick sound lang po talaga. Parang click.Walang redondo. Bagong palit po yung Starter at bagong palit din po yung Carbon Brush sa Alternator. Dati po kasi nadidiskargahan yung battery na toh dahil nga sa alternator, but ayos na nung nilagyan nga nung Carbon Brush yung alternator. Pina-Charge ko lang po ito. Sana Battery nga po. Try ko po dalhin bukas sa Battery Shop. Tanong ko po ulit, kahit po ba umiilaw, may radio, busina, at signal light ehh battery po kaya talaga my diperensya?? Very Tnx po sa lahat ng nag inputs![]()
^^ kung manual tranny ang oto mo, try mo i-kadyot start, kapag nag start na, dahil mo sa tindahan ng battery and pa check mo battery mo and also your alternator.
it's possible your battery is gone.
Sir Art, kahit po ba my power mga components, horn, signal lights, ehh battery na po talaga kailangan palitan?! Pwede po kaya i-charge nalang?? Pagkano po kaya mga motolite ngayun?? TNX
^^ I've experienced that before, click-click lang, walang redondo, malakas busina, umiilaw and all. nung umandar dinala ko sa tindahan ng battery and pina-tsek ko batt and alternator, okay alternator, battery on it's way out.
I don't know what caused it, my battery is well secured and all. so mas maigi dalhin mo talaga sa supplier ng car battery at ipa check mo.
As for magkano, di ko alam kung magkano.
just got my motolite enduro 2sm last month. it costs Php3,300 less P400 kung i-trade in mo ang old battery mo. kasama check-up at succeeding monthly check-ups sa services nung kinunan ko. ma-void din kasi ang warranty kung may defect ang electricals mo e.g. alternator, regulator, etc.
kahit umiilaw at may busina, basta less than 12 volts, baka hindi na mag-start. at madiskarga lalo sa kaka re-start mo, FYI. better palit ka ng new battery kesa itirik ka pa sa daan.![]()
