Quote Originally Posted by spyghost View Post
would the situation be the same for a clutch master?
If the clutch master is bad will leak inside the fire wall follow the connecting rod behind the clutch pedal itself ,if wet its bad You might also look at the slave cylinder and see if it leaks. When it goes bad you will not be able to shift gears, or grind when trying.
