Originally Posted by
tip_tipid
To re-phrase your problem, after being under the sun for about 3 hours, the engine cranks, but there is no ignition. Right?
This condition is normally experienced on caburated fuel system. Ignition
timing setting is critical for some type of engine. Also for carburator type of fuel system, you may try to pump once the accelerator pedal before starting
the engine. Do not press on the accelerator as you are starting the engine.
wait for the engine to run, then press on the accelerator pedal. Hope this can be of help.
