Results 11 to 20 of 31
December 8th, 2007 01:21 AM #11
You had all that done without even doing a compression test?
Palitan mo mekaniko mo. Get one who knows your car's engine.
December 8th, 2007 11:20 PM #12
Are you sure naglaktaw ng isang ngipin ng camshaft? Hindi tama ang ginawa niya, timing marks are there to be aligned. if ever timing is the problem sa injection pump ang correction.
- Jul 2003
- 573
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 9th, 2007 08:27 PM #15seems like your mechanic might be guessing his way to fixing your car. get a 2nd opinion imo.
December 9th, 2007 11:24 PM #16
Timing marks are important and it should be aligned no matter what. No mechanic should do otherwise. It may start your car but it may destroy your engine at high rpm. Double check all timing marks from injection pump, cranshaft to camshaft pati balance shaft narin. May engine manual ba kayo ng engine na ginagawa ninyo?
December 10th, 2007 04:10 PM #17
December 10th, 2007 04:14 PM #18
and kapag nakatama po sa timing ang camshaft,crankshaft,injection pump..ang bagal po tumakbo nung kotse
Tsikot Member Rank 4
- Jan 2003
- 2,979
December 12th, 2007 11:54 AM #19may maling ginawa ang mechanic nyo..... and this would cost you... maaring mali yun pag-adjust nung timing kaya lalo na nasira. hindi nasusunog ng maayos yun deisel nyan kaya mausok. mali ang pagkakabalik ng mga piston rings kaya ayaw humatak kapag tama ang timing kaya inadjust yan dalhin mo sa ibang mekaniko. ano ba area mo baka may ma-irerefer sa yo mga tsikoteer na malapit sa yo. i suggest that you dont use the car muna.
- Mar 2011
- 1
March 6th, 2011 05:09 PM #20mga expert may tanong lang ako regarding sa hard starting din,ford eve 2.5 diesel m/t 2007 model old style.matapos kasi namin linisan yong fuel filter na sing laki lang ng capsule nag hard starting na sya,tapos pag nag start nag vivibrate sya,ano po solution nito? salamat in advance.
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
