Results 31 to 40 of 47
July 21st, 2004 11:26 AM #31
ganit....kaya ang one-click...pero matagal na nagka-crank ang starter...makukuha sa one-time, yun nga lang hindi yung kaagad!
baka tama yung sinabi ni pajerokid sa isang thread:
"Its likely that your GLOW PLUG RELAY is kaput!
Bili na and replace!
This is the component that produces the 'tick' sound every morning. And please make sure that this is the MAIN relay, located in the engine compartment, behnd the batt. Sure ako becauise this happened to me in my previous Pajero."
IMO lang naman...
July 21st, 2004 11:56 AM #32
sa akin naman pag umaga 1 click, but kung ginamit mo yung car
with AIRCON ON then pinatay mo start ulit, yung ayaw ng magstart parang mahina ang rotate ng starter. ano kaya ang problem.
July 21st, 2004 02:02 PM #33Originally posted by acenie
July 22nd, 2004 04:37 PM #34
e bakit pag umaga ok naman. Pag maninit lang ang makina yun parang mahirap mag start mahina ang ang rotate ng starter.
kagaya nung nasa trapik ako naka A/C tapos biglang namatay yung makina den start ko. yung hindi na magstart. hindi na magrotate ang starter.
July 22nd, 2004 06:31 PM #35
Baka madumi na loob ng starter mo. Try mo palinis sa mga may battery shop. I experienced the same on my corolla. One time iniwan ko pa ng sa mall dahil ayaw umandar kahit jumpstart. binalikan ko kinabukasan, isang click lang andar agad. akala ko nga battery kaya takbo agad sa battery shop. Nang check nila, starter daw, kaya nirecomend na linisin nila. they charged me 400 for the labor, pero its worth it.
July 23rd, 2004 01:38 PM #37Originally posted by acenie
more on hard-starting......... don't just focus on the glow plugs, electrical at relays. maaring may leak ang fuel line mo at nawawalan ng diesel ang mga injectors. kapag ganito ang case kahit gumagana pa ang glowplugs mo wala naman fuel sa injectors kaya hard starting sya not until na nag-crank ilang beses yung engine aakyat ulit ang fuel sa injectors i-start na sya.
- 10,620
August 19th, 2004 10:16 AM #38yup check also the battery baka rin mahina na ang charge.
maski pa ok ang glow plugs kung mahina ang batt, hard starting pa rin.
October 16th, 2004 04:23 AM #39
Question lang po is it the same for Cars? I'm reviving this thread because I've recently encountering the same hard starting with my jalopy.
October 16th, 2004 11:15 AM #40
Marami din pong causes pag gas-fed engines, instead of checking glow plugs, spark plugs. Or fuel isn't enough to start the engine.
Kailan nyo po ba nararamdaman ang hard starting? After an hour rest, overnight parked, o pag mainit na ang makina?
high idle RPM at engine start
