*Ry_Tower
Afaik some VW TDis have this installed as OEM. I would imagine dapat lang meron na from factory yung mga premium German brands nito kung VW lang meron na. Just in case maambunan ako ng pork at makabili ako ng German pwede ko ilipat dun yung unit.
*monty_GTV
Yes sir a bit expensive but it should do the job much better than the generic OCCs. As I mentioned above we can transfer it from vehicle to vehicle if ever it's time to sell the car. Also at around 7K I wouldn't consider this expensive in relation to the cost of modern diesels, which are now 1.1M up. That's not even 1% of the car.
*TheGreenThing
Your OCC looks pretty effective sir. Has any oil made it past the OCC into the intake? Is there any water in the oil?
*crazy_boy
Yup, ang laki ng inlet and outlet, 25mm for the 200. Pero yung 16mm of the 150 should be enough. Yung filter element around 80,000-100,000 Kms of use daw. Not bad hehe.
I'll try to update this when info on availability comes.
