Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Hi guys,
    Nakikita ko ito sa carshows eh, may nakapg try na ba sa inyo nito? Posible ba talaga?
    All inputs are highly appreciated.
    TnX...
    Feb 2013
    Quote Originally Posted by erick_214 View Post
    Hi guys,
    TnX...
    Oo naman, just expect that you will shell out a lot para maging talagang in good running condition sasakyan mo.
    possible naman yan. madami lang papalitan na parts. pati mga gauge papalitan lahat.
    Posible ba talaga?
    of course
    palit makina
    Feb 2013
    of course
    palit makina
    Kahit differential at transmission palit yan.
    Huh, kasi sabi nung nagtanong ako parang may ikakabit lang silang equipment tapos pwede nang gamitan ng diesel. Hindi lang ako nakapag tanong pa in details busy kasi sa pag-ikot ikot eh.
    Aug 2004
    Yeah. That equipment is a new motor.
    You can't run a gasoline engine on diesel. You can convert it to diesel by changing out the entire fuel system, welding the holes in the cylinder head shut, changing out the pistons for high compression ones (gasoline compression is usually 9:1 to 11:1. Diesel is ariound 22:1 if you don't have a turbo), changing the connecting rods for stronger ones to take the extra pressure, reinforcing the engine block, changing the camshaft grind, etcetera.
    That kind of work on an engine will cost you more than the car is worth. To swap in a diesel engine, instead, will cost you some 100k pesos. To simply sell your car and buy a diesel car which already has the correct transmission, gauges and tank will cost even less.
    huh?
    equipment?!
    iba ang compression ng gas engine sa diesel engine
    hindi kakayanin ng engine block ng gas engine ang pressure ng diesel
    hindi din kaya ng internals. ang liit ng mga piesa ng gas engine
    iba din ang cylinderhead
    baka kino-convert ng mahiwagang equipment yung diesel fuel to gasoline
    magic!
    Tama sila uls, siopaonatoasted at niky.
    Sent from my Nexus 7 using Tapatalk 2
    di kaya inventor ng khaos yung nakausap mo hahahaha!
Gas to Diesel Convertion
