Results 1 to 10 of 15
- Jul 2008
- 935
June 11th, 2013 02:34 PM #1Hi guys,
Nakikita ko ito sa carshows eh, may nakapg try na ba sa inyo nito? Posible ba talaga?
All inputs are highly appreciated.
TnX...
BANNED BANNED BANNED
- Feb 2013
- 487
June 11th, 2013 02:42 PM #2
June 11th, 2013 02:42 PM #3
possible naman yan. madami lang papalitan na parts. pati mga gauge papalitan lahat.
- Feb 2013
- 487
- Jul 2008
- 935
June 11th, 2013 04:49 PM #6Huh, kasi sabi nung nagtanong ako parang may ikakabit lang silang equipment tapos pwede nang gamitan ng diesel. Hindi lang ako nakapag tanong pa in details busy kasi sa pag-ikot ikot eh.
June 11th, 2013 05:05 PM #7
Yeah. That equipment is a new motor.
You can't run a gasoline engine on diesel. You can convert it to diesel by changing out the entire fuel system, welding the holes in the cylinder head shut, changing out the pistons for high compression ones (gasoline compression is usually 9:1 to 11:1. Diesel is ariound 22:1 if you don't have a turbo), changing the connecting rods for stronger ones to take the extra pressure, reinforcing the engine block, changing the camshaft grind, etcetera.
That kind of work on an engine will cost you more than the car is worth. To swap in a diesel engine, instead, will cost you some 100k pesos. To simply sell your car and buy a diesel car which already has the correct transmission, gauges and tank will cost even less.
June 11th, 2013 05:18 PM #8
huh?
equipment?!
iba ang compression ng gas engine sa diesel engine
hindi kakayanin ng engine block ng gas engine ang pressure ng diesel
hindi din kaya ng internals. ang liit ng mga piesa ng gas engine
iba din ang cylinderhead
baka kino-convert ng mahiwagang equipment yung diesel fuel to gasoline
magic!Last edited by uls; June 11th, 2013 at 05:21 PM.
June 11th, 2013 09:07 PM #9
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
