Results 11 to 20 of 27
July 5th, 2012 12:27 PM #11
dapat may DRIVER ADDITIVE
nilalagay sa driver para di gigil umapak sa accelerator
that will save fuel
July 5th, 2012 12:29 PM #12
^ nadadamay na lang yung iba kasi actually yung catch na talaga nagpapabenta dyan eh yung fuel savings ek ek IMO. Pero yeah, some fuel additives helps in cleaning and prolonging good performance of engine. Power booster afaik gray area din.
July 5th, 2012 02:58 PM #14
Let's put it this way.
Buying an expensive additive is like buying Noni Juice at over a thousand pesos a bottle when simply buying some fruit at the "palengke" will give you the same benefits for much less.
It's like buying those MLM vitamins in super-dose sizes... 1000 mg+++ capsules of Vitamin C... when in reality your body can't even absorb that much, and it'll all go out the other end when you go to the bathroom (just like GTOil, which has three times the zinc that is considered safe for engines).
It can get even worse, if you consider octane additives... which, for hundreds of pesos, add just 1 RON to your gasoline's octane... when just spending the same amount of money on a tank of gasoline can give you an extra 5 RON (95 RON Premium versus 100 RON Blaze).
Your engine can use extra lubrication. It can use extra additives. It can use extra RON (but the only time this will gain you fuel economy is if you're using the wrong RON in the first place). But buying a separate additive for this is like buying your flouride toothpaste from Amway instead of the supermarket.
July 6th, 2012 10:00 AM #15
2t works and is lab tested so I would not say all fuel additives don't work.
July 6th, 2012 11:08 AM #19
yung friend ko sa delica nya naglagay sya ng fuel additive... ayun 1 week lang nasira injection pump nya... kaya ingat po tayo sa pag lagay ng fuel additive....
July 6th, 2012 11:14 AM #20
Power and fuel economy don't mix. Either give up one for the other. Can't have both of them, whomever is thinking that a Ferrari can blast down the highway with the fuel economy of a Vios must be high on glue or something.
That being said, nothing beats a well maintained and properly tuned engine. No excuses!
Now am just waiting for somebody to jump in on the bandwagon and sell their part of the fuel economy shindig of a story!
Means "Sedan" in japan... Sakanila yung civic na 1997 may ferio sa ilalim nang civic na logo at...
Civic horsepower
