Results 11 to 17 of 17
May 27th, 2003 07:02 AM #11
draining the fuel tank once in a while would help too in reducing dirt and water build up in the systemsince some diesels are really dirty and contaminated with water.
May 27th, 2003 12:57 PM #12
hmm.. boss doc!... sayang nde ko nalaman about this carbon clean when i visited the makati shop about a leak in one of my injectors....
my engine is a 1979 3.0L MB diesel engine.... when you say more detergent.. this means one treatment but stronger? o multiple treatment in phases?
01 EX Ody
- 437
May 27th, 2003 01:55 PM #13Originally Posted by HBOY
8 oz. of detergent would be consumed in more or less an hour. The more detergent, the longer engine running period. Take note ha, that we need to run your engine while it consumes the solution.
You might wonder, 8 oz. lang? or Bakit ounce ang measurement? A bottle for diesel detergent which is 16oz. is already strong in a sense that it can knock you down.
Doc Diesel
May 27th, 2003 02:19 PM #14
ahh...ganun ba? lakas pala nung detergent na yun.. tawag na lang ako sa shop nyo to inquire about the price.. tnx.... tagal pala 1 hour.hmm.. is that one hour under a load? o idle?
01 EX Ody
- 437
Tsikot Member Rank 3
- Dec 2002
- 636
May 28th, 2003 07:55 PM #16Doc Diesel,
Where or how do you connect the carbon clean machine on the fuel system?
What effect would your detergent have on the additives/detergents in the engine oil?
01 EX Ody
- 437
May 29th, 2003 08:51 AM #17Originally Posted by jackaroo
for gasoline: going in through the carburetor / fuel pump then out to the return line of the carburetor or the aluminum manifold for fuel injected.
Doc Diesel
high idle RPM at engine start
