[quote=paulgozon;1407609]Assuming you have a good starting system, sa umaga pag-hindi siya start try open a bolt on the fuel line (either the filter or common rail) and see if there is a pressurised gasoline. If you don't know how to do it, go to your favorite shop and let them know of your intention so that they can help you with it. We are trying to isolate the problem by first checking if the problem is from the fuel pump.
dinala ko kanina sa car repair dahil dalawang beses namatayan sa daan at hirap din magstart. chineck nila ang fuel pressure at malakas naman ang sirit ng gas. pinacheck ko sa electrician sabi niya maluwang yung connection sa computer box. sinecure niya at umuwi na kami. under observation as of now.
