Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Jul 2013
    mga sir tanong ko lang po.. im having this issue na habang tumatakbo ako and split second na bigla akong parang nawawalan ng hatak tpos biglang babalik sa dati..is it because of my fuel pump na hindi na nakakasipsip ng maayos or is it my distributor cap na baka worn out na? bka may mga masshare kayo na pwede kong tingnan or i check..
    more power to you guys..
    Feb 2009
    Quote Originally Posted by IllidanCarlisle View Post
    not enough information to even make a wild guess
    Jun 2011
    anong oto nyo sir? kong nawawala hatak maraming pwde pang galingan yan paki txt nalang ako sir baka baka maka tulong ako,09281904001 mike po tnx.
    matic o manual? anong oto?
    Jul 2013
    sorry sir.. hehe..
    mazda 323 96' yung oto sir..manual transmission..
    may palya ba sa idle?
    Jul 2013
    pag naka idle sir wala pong plya.. habang tumatakbo cya dun nagkakaron.. split second na parang nawalan ka ng gasolina tpos biglang hahatak.. nakakatakot lang kc pag sa superhighway nangyayari kahit nsa slow lane ako bigla biglang nagkakaganun eh..
    Sounds like a slipping clutch to me. Kelan ka last nagpalit clutch dics and pressure plate? But still have it check. Malabo kasi misfire kung walang palya sa idle.
    Aug 2010
    sir, parang sinisinok ba? pa check ho spark plugs.
    Jul 2013
    Quote Originally Posted by alfonsomiguel View Post
    oo sir pero hindi cya constant.. just checked the spark plugs this morning.. ok naman cya.. 6 months + na yung sparkplugs since nung nagpalit ako..
    Aug 2010
    sir, sa akin palit ng spark plug kahit sa tingin ay ok pa. nawala naman ung pag-sinok. sabi ng mechanic ko, pede rin na ignition coil na pumapalya. since yung plugs ko more than 6mos na rin. Yun muna ang pinalitan. OK naman so far.
    Jul 2013
    thank you sir.. will take a look at that.. nawala yung "sinok" issue nya nung nagpalit ka ng sparkplugs?
    BTW dapat ba ngk lang na sparkplugs lang ang gamitin ko? nka bosh ako na super-4 na sparkplugs ngayon..
    More like a Fuel filter or Pump failure. When was the last time you replaced your filter? Also, your fuel pump might already be faulty which restricts fuel or doesnt give enough fuel to the engine during higher RPM (above idle RPM)
    Jul 2013
    Quote Originally Posted by jvnj View Post
    thanks for the input sir.. the filter was changed 6 months ago nung nag pa change oil / tune up ako.. saka may parang gumagaralgal sa ilalim ng upuan sa likod where the fuel pump is..
    Jul 2010
    Quote Originally Posted by [archie] View Post
    Parang sa supply ng fuel problem. Pwede rin intermittent nag luko yun lumang Ignition Coil kapag umiinit na makina. During high rpm ay mas mainit ang Ignition Coil at mag open ang winding coil. Pero kung di mo ma-experience ito na malamig pa engine mo ay sa fuel pump nga . Or may loose connector contacts sa supply ng fuel pump. Carb type ba ang Mazda 323 96?
    Jul 2013
    Quote Originally Posted by Chinoi View Post
    fuel injected sir.. and tama kayo kapag bagong start mga 15-20mins after during mainit na yung makina dun na cya nagsstart "suminok"..
    Kala ko walang palya sa idle?
    Jul 2013
    pag nka idle sir wala po cyang palya.. naitatakbo ko cya pero after mga 15-20mins nagsisimula na cya suminok.. pag nkahinto lang ako or naka idle wala yung sinok nya.. habang tumatakbo lang sya saka nagkakaron ng sinok..
    Ahh ok. Kala ko nawawalan lang ng hatak. Hehe
    Parang trial and error pwede gawin. Eliminate fuel pump, malabo sira yun. As said, coil can be a suspect. Mahirap trace kasi kung wala sa idle.
    Jan 2011
    mukhang kapos ng fuel. subukan mo munang i trace ang fuel line. baka maruming tangke, sirang pump o kaya barado ang filter. unahin mo ang mura gawin.
fuel pump or distributor cap?
