Results 11 to 20 of 28
- Aug 2010
- 86
August 5th, 2013 05:49 PM #11sir, sa akin palit ng spark plug kahit sa tingin ay ok pa. nawala naman ung pag-sinok. sabi ng mechanic ko, pede rin na ignition coil na pumapalya. since yung plugs ko more than 6mos na rin. Yun muna ang pinalitan. OK naman so far.
- Jul 2013
- 26
August 5th, 2013 09:10 PM #12
- Nov 2008
- 641
August 6th, 2013 05:23 PM #13More like a Fuel filter or Pump failure. When was the last time you replaced your filter? Also, your fuel pump might already be faulty which restricts fuel or doesnt give enough fuel to the engine during higher RPM (above idle RPM)
- Jul 2013
- 26
August 7th, 2013 09:30 AM #14
- Jul 2010
- 570
August 7th, 2013 10:49 AM #15Parang sa supply ng fuel problem. Pwede rin intermittent nag luko yun lumang Ignition Coil kapag umiinit na makina. During high rpm ay mas mainit ang Ignition Coil at mag open ang winding coil. Pero kung di mo ma-experience ito na malamig pa engine mo ay sa fuel pump nga . Or may loose connector contacts sa supply ng fuel pump. Carb type ba ang Mazda 323 96?
- Jul 2013
- 26
August 7th, 2013 07:05 PM #16
- Jul 2013
- 26
August 7th, 2013 08:09 PM #18
August 7th, 2013 08:18 PM #19
Ahh ok. Kala ko nawawalan lang ng hatak. Hehe
Parang trial and error pwede gawin. Eliminate fuel pump, malabo sira yun. As said, coil can be a suspect. Mahirap trace kasi kung wala sa idle.
August 7th, 2013 08:56 PM #20
mukhang kapos ng fuel. subukan mo munang i trace ang fuel line. baka maruming tangke, sirang pump o kaya barado ang filter. unahin mo ang mura gawin.
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
