Results 21 to 30 of 55
October 28th, 2005 08:19 AM #21
does changing of the oil and changing to open type filter or having a snorkel installed reduce black smoke? i have the things done and seemed to help a lot....
01 EX Ody
- 437
October 28th, 2005 12:15 PM #221 more day...last call....
1. Tell tale signs to look out for.
2. Signs or what to look out for other types of services.
3. Engine diagnosis [somewhat related to tell tale signs].
4. Calibration flow chart with solutions. Tools will not be included as this are not ordinary tools.
5. How to drive diesel engines without smoke belching.
6. Emission testing.
7. Calibration timelines or recommended intervals either in years or odo readings.
8. Oil changes, Biodiesel and other additives.
9. Accessory add ons ot help the engine.
I'll do everything this weekend so answers will be posted by monday in several formats like .doc, .pdf, .txt or .html or simply posted everything here.
01 EX Ody
- 437
October 28th, 2005 12:23 PM #23Originally Posted by ARB
How did you know those were the ones that needed replacement? And how did you know that those part numbers are for your specific application? I am presuming you have the old mechanical style in line injection pump where other shops have the habit of changing only certain parts to have a lower quote but do not know that other parts are vital to each other also.
para bang man and wife........
san province ka?
October 28th, 2005 07:11 PM #24
its for a fuso 8dc81a engine, inline. OEM was zexel p49. replacement of Denso was 461-0. symptoms was, no idle, and if I adjust ang idle it would go wild. When we pulled out the plunger and barrel it was heavily worn out it had already streaks. had tried to have it adjusted first but ayaw talaga mag idle. did not change the delivery vavle as there was no stock here and it was ok pa naman. now one click na ang truck and idles well.
Neg. occ.
01 EX Ody
- 437
October 28th, 2005 09:36 PM #25Originally Posted by ARB
October 29th, 2005 07:30 AM #26
yep we removed the pump from the truck, had it ride the calibration machine and it cannot hold idling pressure to the nozzle at 200 rpm. from a auto supply here, yep after replacing calibrated it again.
October 29th, 2005 07:20 PM #27
also pwede pa discuss na rin which replacement parts to avoid and the cheaper but reliable alternative brands to buy
October 30th, 2005 01:55 AM #28
Originally Posted by lancelot
46K palang? 2000 model siya bago pa unit mo and super low milage. 2 years na bumagsak sa emission? akala ko pa naman very durable ang 4m40 natin
November 7th, 2005 09:58 PM #30
Looks like Doc has his hands full.
Gary, boybi : pa sticky naman tong topic.
I do not have technical knowledge on cars. Since I am scouting for a new ride (I already have an...
BYD Sealion 6 DM-i
