Originally Posted by
oj88
Carbon buildup in the combustion chamber, pistons, valves, and downstream of it to the cat or DPF.
Lookup cylinder wall glazing. Glazing means that the factory crosshatch has been polished off due to the unburned/excess fuel from long idling, washing off the coat of oil off the cylinder wall. Long idling also does not produce enough combustion pressure for the piston rings to seal properly, thus allowing unburned fuel to seep through. The crosshatch is there for oil to stick to, working in conjunction with the piston rings to seal as much of the combustion as possible. With the crosshatch polished off and as it becomes shiny and smooth, oil doesn't cling to it as much and no amount of OCI regimen would fix that. The block is essentially ruined.
As a result of cylinder glazing, more blow-by gasses can get through, accelerating fuel bi-products dilution of the oil, as well as reducing the compression ratio and the overall engine performance.
Increased blow-by will also inject more oil back into the intake via the PCV system. So, going back to your first question, that will definitely be a source of carbon buildup on the intake valves, particularly on DI engines.
