Results 1 to 10 of 21
- Feb 2008
- 898
March 28th, 2019 03:59 PM #1I usually see owners/drivers of vans (Hi-Ace, Urvan, Starex, and the like) running their engines with the aircon on for several minutes like for more than 30mins to an hour at the parking area. I know these are diesel engines. But is this okay? What are its adverse effects, if any? Fuel consumption? Is this practice ok because they are vans? what about SUVs doing this, what would be their difference?
How about those cars on gas engines also doing this practice of running their engines with the aircon on for several minutes?
Pls enlighten me on this. I am not doing this to my ride (Fortuner Diesel AT 2016), but still I am curious.
- Nov 2009
- 3,490
March 28th, 2019 04:28 PM #2There is a great possibility of carbon monoxide poisoning running on stationary confined areas with a gas engine than a diesel.
Diesel engines are thermally efficient running with hot environment, gaso don't like hot environments. Economy-wise torque/power/energy content per unit fuel is for diesel, that is why you don't see an industrial generator or mass transport bus/ trucks with gasoline engine.
I sleep in my diesel van 30mins to 2hrs esp during long drives when i get sleepy or tired. I am still alive and my brain cells are still intact.
- Oct 2006
- 5,771
March 28th, 2019 05:03 PM #3
- Dec 2013
- 680
March 28th, 2019 05:18 PM #4
March 28th, 2019 05:53 PM #5
the cooling system simply works as well as the ac system. there was a graph before how these works.. its an on and off cycle for these older systems.
newer system employ inverter like characteristic..
March 29th, 2019 04:52 PM #6
Toyota Hiace vans can run for 24 hours straight when they are hired to travel to provinces ... Nissan vans will overheat ...
- 52,996
March 29th, 2019 05:13 PM #7
March 29th, 2019 06:43 PM #8
That practice is always detrimental to the engine's health. Long idling creates more carbon build-up, contributes to fuel dilution in oil, increased cylinder wall wear, which then results in more blow-by.
It's especially bad for modern Diesels equipped with DPFs.
As the effects are not immediate, many people see engine idling as harmless. But there's a reason why long idling and/or stop and go traffic, among other things, are considered severe or extreme conditions on almost any vehicle owners manual.
- May 2014
- 1,318
March 29th, 2019 07:29 PM #10Well, regarding this. I think most cars now have an Auxiliary Fan that deals with cooling the aircon system/compressor, be it gas or diesel I believe (not sure which cars we have here that have an electric compressor though)
So as the cars age, that auxiliary fan will stop working and there will be no warning light.
And with that failure, your aircon system will not work properly as there isn't sufficient airflow to cool the compressor.
So when idling and AC is running, well, you aren't in motion. Tendency is your car won't actually be cooling you in the cabin.
I don't personally like idling my car but there would be instances where it might be unavoidable (with kids or elderly inside the car while waiting for someone to come out of the house or store, etc etc).
Keep it to a minimum I say.
Ok nga Avanza at Innova. Starex ok din.
Buying a second hand car for under 300k
