Results 11 to 20 of 21
March 29th, 2019 07:31 PM #11
- Nov 2009
- 3,490
March 29th, 2019 08:36 PM #12^EGR opens during those idling moments, hence the more exhaust gas passing the intake and the more it makes the oil acidic.
March 29th, 2019 11:35 PM #13
Carbon buildup in the combustion chamber, pistons, valves, and downstream of it to the cat or DPF.
Lookup cylinder wall glazing. Glazing means that the factory crosshatch has been polished off due to the unburned/excess fuel from long idling, washing off the coat of oil off the cylinder wall. Long idling also does not produce enough combustion pressure for the piston rings to seal properly, thus allowing unburned fuel to seep through. The crosshatch is there for oil to stick to, working in conjunction with the piston rings to seal as much of the combustion as possible. With the crosshatch polished off and as it becomes shiny and smooth, oil doesn't cling to it as much and no amount of OCI regimen would fix that. The block is essentially ruined.
As a result of cylinder glazing, more blow-by gasses can get through, accelerating fuel bi-products dilution of the oil, as well as reducing the compression ratio and the overall engine performance.
Increased blow-by will also inject more oil back into the intake via the PCV system. So, going back to your first question, that will definitely be a source of carbon buildup on the intake valves, particularly on DI engines.Last edited by oj88; March 29th, 2019 at 11:43 PM.
- Aug 2017
- 319
March 30th, 2019 09:35 AM #14
- Aug 2017
- 319
March 30th, 2019 09:39 AM #15
- Aug 2017
- 319
March 30th, 2019 09:44 AM #16
March 30th, 2019 10:05 AM #17
March 30th, 2019 10:36 AM #18
Short answer is a likely, yes.
Long answer. In the context of emergency power generators, engine wear is kind of a given and is usually sacrificed for instantaneous and unplanned emergency operation. Many of these typically large generators are automated and will start itself upon sensing a power failure and immediately rev-up to a usual 3000 RPM and immediately supply power to its load (used mostly in hotels, malls, hospitals and large commercial establishments), without so much as a 10-second warm-up.
But one factor that affects the cylinders is the loading. Under-loading a genset is as bad as running it at idle for long periods of time. This link suggests that Diesel engines must be loaded at around 60-75% of its total capacity to provide adequate seal on the piston rings and prevent or at least reduce the possibility of glazing.
In other words, don't put a 10kVA genset when a 3 or 5kVA is all you need... UNLESS there's absolute value in having a higher kVA headroom over the life of the genset.Last edited by oj88; March 30th, 2019 at 10:38 AM.
March 30th, 2019 10:37 AM #19
March 30th, 2019 11:01 AM #20
Good thing you don't have an oil pressure gauge. It'll make you think twice about going 50.
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
