Results 1 to 10 of 17
- Feb 2008
- 577
June 23rd, 2008 05:35 AM #1hi,
can i remove the stock muffler and flush it with water and/or solvent to clean the inside?
when you take a look at it from the outside, its black inside... kinda a build up of 8 years of dirt and everything.
June 23rd, 2008 07:46 AM #2
NO! You dont cleaned the inside of a muffler, its not a serviceable component, except replacement. Muffler are usually packed w/ fiberglass depending of muffler u got, if water would stuck one for sure, mess everything up. Buy a new one, get rid of thet 8 yrs old muffler they are very cheap.
- Feb 2008
- 577
June 23rd, 2008 07:49 AM #3if that is the case, what about the whole exhaust piping? can it be flushed?
except the cat of course.
June 23rd, 2008 07:55 AM #4
June 23rd, 2008 10:39 AM #5
June 24th, 2008 11:03 AM #6
What are the things to consider on Changing an Old dirty muffler?
Do Shops usually have the Same Model?
Price Range po?
Thank you!!
June 24th, 2008 11:49 AM #7
Or you can take it on a sustained high speed run to clean up the carbon deposits in the exhaust. It's also much healthier for the car, because the oil will be hot and circulating, protecting the engine bits, and plus, you're not stressing it on stop-and-go heavy traffic situations.
- Feb 2008
- 577
June 24th, 2008 12:18 PM #8nanigas na kasi yung mga itim sa loob ng muff e. i want to restore sana the orig finish so that i can also gauge the deposits that will come off my engine
June 24th, 2008 12:47 PM #9
*spyghost: are you referring to your glx lancer? A gas engine fed like yours do not need an exhaust clean up using water and alike. Have you noticed that gas fed exhaust system are more vulnerable to rust? (nadudurog at napuputol) compared to diesel fed na hindi kinakalawang? what more if you use water and solvents alike. ihataw mo lang once in a while a.k.a. italian tune maalis na at makaka hinga na siya ng maluwag. normal lang to have carbon deposits anyway don't worry.
For diesel fed yes you can use water and solvent / detergent but with exceptions too like those who have catalytic converters. mahal yun pag nasira!
June 24th, 2008 01:53 PM #10
At the expense of rear cargo space. The floor is raised around 8inches for the batteries.
2021 Toyota Land Cruiser LC300
