Page 1 of 3 123 LastLast
Results 1 to 20 of 58
    Jun 2008
    Tsikoteers, I'm due for change oil this month and want to try fully synthetic oil for my diesel ride. Unfortunately, I cannot find any syn oil with 15W-40 in laguna area. Only syn oil available is 5W-40(castrol,shell), and 20W-50(shell). which of the two i can use and is okay for an diesel engine.
    castrol magnatec semi-syn has 15w40. but too magnetic for me, kahit sa kamay, ang hirap tangalin. I think myroon din mobil 1 full synthetic, and Royal Purple.
    Royal Purple has the most praise here in tsikot.
    more info here:
    http://tsikot.yehey.com/forums/showthread.php?t=48274
    Jun 2006
    Royal Purple has full synth 15w40. PM or call Speedyfix for a dealer near you.
    Petron has a synthetic diesel oil. Rev X Trekker or something like that. But its 5w30 if memory works.
    ok ba ang eneos? highly recommended nang ibang enthusiasts kasi ito daw ang oem oil manufacturers ng most japanese automotive vehicles
    Nov 2007
    from castrol CRb i shifted to Petron trekker or all terrain. Mas maganda ang engine performance when i used the petron oil
    Jun 2008
    I would really like to try Royal Purple but i could not find it here in laguna. Petron trekker is it synthetic not fully synthetic? Correct me if I am wrong, kasi yun nakikita ko sa label na "synthetic technology" does it mean fully syn or semi-syn??
    Nov 2007
    Quote Originally Posted by vlad123456 View Post
    yup, trekker is semi synthetic but the all terrain is fully synthetic. Mas cheaper kasi ang trekker and wala naman problem if i use the semi syn as long as i follow the regular pms. actually when i was in college naalala ko yung professor ko in lubricants na against siya in using fully synthetic, mas prefer nila ang mineral base oil or the semi synthetic. fully synthetic although is good pero madali daw magcarbonize unlike the mineral or the semi. anyway just follow the regular pms of our car i think hindi problem kung kineral, semi or fully as long as your satisfied.
    Jul 2006
    Check the rating at the back of the bottle, it should be diesel-rated. You can tell if it has a C instead of S when checking the ratings. If it's S-rated only, it's not designed to handle diesel soot, but can be used temporarily as an emergency oil. Replenish with correct type as soon as possible.
    For me I went from dino to semi-synthetic muna. Baka mabigla sasakyan ko. So far so good, I get better starts and feels a bit lighter with 5W-40 (here in the US I use Shell Rotella). Might use it for a while I think my car likes it.
    You didn’t mention the engine type. IMO it’s just a waste of money to go fully synthetic if the manual says not. as long you follow the right viscosity and intervals then definitely it will serve you well. changing every 4000 kms the better and cheaper too.
    if i will go into fully synthetic, petron all-terrain would be my first choice. budget wise, it's the cheapest among locally available brand.
    Jan 2008
    Pag turbo diesel mas maganda semi-synthetic or fully sythetic, pero sabi ng mga tekno with CL-4 or CL-4 plus oil service rating, di na nagkakalayo ang performance ng mga diesel motor oils as the added test criteria (14 ASTM tests to pass vs 12 tests with API CH4) will eliminate the use of poor quality base stocks and additives.
    Apr 2008
    tanung lang din mga peeps.. anong engine oil ba ang ok sa crdi engine? gamit ko kase kahit sa ibang diesel ko ay 15w40.. regular ang change oil ko, sabi kase ng mekaniko ko, ok na daw yung oil ko. sinusunod ko nman daw pms ko, saka pati mga filter ko, palit kung dapat palitan.. tia
    Jun 2007
    same with my mechanic sir glenn_sp, sabi rin ng head mechanic sa casa ng isuzu (inteco), iyung sportivo daw hindi puwede gamitan ng besco oil nila na 5w30 yata iyun kasi mag leak daw mga oil seals. Sabi nila, basta daw sundin iyung pms ng auto or kung gusto daw is mas earlier the better mag change oil. Ginamit yata namin iyung isuzu oil na straight 40 ang rating.
    contact mo speedyfix, kung puwede e-padala through AP Cargo.
    afaik, crdi use 10w-below. oil required is lighter than most old school engines.
    Oct 2007
    [IMG]file:///C:/DOCUME%7E1/Gemma/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
    Valvoline’s Premium Blue Engine Oil is designed to provide advanced lubricant performance in modern, emissions treatment equipped diesel engines, including all types of Exhaust Gas Recirculation (EGR) and Diesel Particulate Filters (DPF). When used in conjunction with Ultra-Low Diesel Sulfur fuel, this product technology offers a long-life, extended drain capable*, balanced formulation which helps maximize engine durability as well as after-treatment cleanliness.
    The Premium Blue Advantage:
    • Unique dispersive polymer technology (DPT),with premium Group II baseoil, provides advanced soot control, and cold start protection.
    • Valvetrain wear protection and reduced oil filter restriction at high soot levels.
    • High temperature deposit control, including single and two-piece pistons, and ring/liner wear protection.
    • Higher TBN level and TBN retention for long-life performance, while meeting all chemical limits.
    • Endorsed and recommended by Cummins for use in Dodge Ram Turbo Diesels
    Valvoline’s Premium Blue Engine Oil is endorsed by Cummins Engine Company and has been tested extensively by Cummins in stationary and on-road EGR engines, including those equipped with DPFs. It is approved against the CES 20081 specification.
    How it Works
    Premium Blue contains DPT — Dispersive Polymer Technology — a proprietary combination of additives that protects against soot-related valve train wear and reduces piston deposits, ring wear, liner polishing, and filter plugging.
    While providing extended protection from thermal degradation and corrosion due to higher temperatures and acids from cooled Exhaust Gas Recirculation (EGR), DPT keeps soot particles in suspension so that the oil maintains optimum flow characteristics in cold weather and at operating temperatures.
    Product SpecsValvoline’s Premium Blue Engine Oil is endorsed by Cummins Engine Company and has been tested extensively by Cummins in stationary and on-road EGR engines, including those equipped with DPFs. It is approved against the CES 20081 specification. It will also be approved against Mack EO-O Premium Plus 2007, Volvo VDS-4, and DDC Power Guard 93K218 specifications. It exceeds the lubrication requirements for Caterpillar, Detroit Diesel, Navistar, other heavy duty diesel engines, including engine performance requirements of Caterpillar ECF-3 and the Global DHD-1 Specification. The product meets API CJ-4, API CI-4 Plus, API CI-4, API CH-4,CG-4, CF-4, CF / SM, the performance requirements of ACEA E3-96, E5-02, E7-04 and the engine requirements of DB 228.3 ,MTU Type 2/Type 1, DDC 2000/4000 Series Type2/Type 1, MAN 3275, MAN 271. It provides excellent performance in “mixed fleet” gasoline engines, pickup and delivery, city fleet, long haul over-the-road, and off-highway applications.
    I would have to recommend this non-synthetic base engine oil from valvoline(as the Valvoline premium blue extreme fully synthetic engine oil is not yet available here in the philippines). As this is the only locally available diesel engine oil that meets the latest Api CJ-4 to my personal knowledge, this would be the best rating to date available locally.
    an sae 15w-40 is best suited for our country as we our engines could experience upto 40 degrees of heat but not less than 15 degrees of coldness.
    Jun 2008
    guys, maraming salamat sa replies. hilander nga pala ride ko. another question, pag nag fully synthetic ako, is it ok to increase PMS interval to 10,000 km or 6 mons whichever comes first.
    Not to disappoint you, pero 4ja-1 ng highlander is considered as one of the old school diesel engines na tumatakbo pa. Kung yung mga patrol (ZD30) at pajero (4d-56 and 4m40) with turbos pa are not recommended to go full synthetic yung atin pa. isa pa hindi rin recommended sa diesel na mag 10,000 kms interval, the frequent the better.
    I suggest mag mineral ka na lang tapos i-change oil mo every 3,000 or 4,000 kms. Ramdam mong smooth siya dahil malinis na malinis.
    My 1 cent.
    check mo rin mga oil thread discussions, marami yan
    Jun 2008
    *XTO
    thanks for the recommendation. By the way, what oil do you use? para may reference ako.
    Jun 2008
    *XTO
    Jun 2008
    valvoline durablend 10W-40, locally available ba 'to (ace hard, etc...)?
    Nov 2003
    for most of the diesel engines, a 40 weight oil will be best. there are of course some exceptions but unless you own an isuzu that's the rule for most.
which oil is better for diesel??
