Results 1 to 10 of 17
- May 2008
- 21
December 6th, 2016 09:49 PM #1On a cold engine, erratic ang idling and parang mamamatay ang makina pag tinatapakan ang accelerator pedal. Vios 05, 1.5 AT.
Nakapagpalit na ko ng 2 ignition coils before. D kaya may faulty sa supply ng kuryente sa spark plug? Btw, bago ang spark plugs. Standard OEM.
Thanks sa sasagot.
- Jun 2005
- 3,774
December 6th, 2016 11:33 PM #2^ try having the throttle body and maf sensor cleaned.
If you have facebook, look for the toyota vios maintenance group. Ganyan discussion dun
- Dec 2016
- 39
- May 2008
- 21
December 8th, 2016 06:03 PM #4
- May 2008
- 21
December 8th, 2016 06:07 PM #5
December 9th, 2016 07:28 AM #6
Yung fuel filter sir nagpalit na kayo?
Sent from my SM-N7502 using Tsikot Forums mobile app
December 9th, 2016 02:53 PM #7
Kapag ganyan pinagawa mo na physical checks and the problem is still persistent, I suggest magpa OBD scan ka na muna.
It's just a little expense para malaman mo specific na papatignan once you get the results
Sent from my Asus ZenFone 2 using Tapatalk
December 10th, 2016 07:49 AM #8
Please define/describe erratic idling on a cold engine. The more details you have the easier the diagnosis
- Oct 2016
- 3
December 27th, 2016 07:33 PM #9Good Pm po, i have same issue nag punta ako sa dealership at nag pa diagnose ng issue, sabi nila I need to replace my MAF sensor, sobrang mahal ng piyesa, okay lang ba gumamit ng second hand na MAF? Mazda 3 2005 ung kotse ko.. Thanks sa mga sasagot
December 27th, 2016 07:40 PM #10
What it is the airflow indication on the scanner? It should be around 1 gram per second per liter of engine displacement. Check other engine parameters. The engine vacuum should be between 17 and 21 inches of mercury. Use gauges, do not base your judgment on opinions and guesses
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
