Results 1 to 17 of 17
    May 2008
    On a cold engine, erratic ang idling and parang mamamatay ang makina pag tinatapakan ang accelerator pedal. Vios 05, 1.5 AT.
    Nakapagpalit na ko ng 2 ignition coils before. D kaya may faulty sa supply ng kuryente sa spark plug? Btw, bago ang spark plugs. Standard OEM.
    Thanks sa sasagot.
    Jun 2005
    ^ try having the throttle body and maf sensor cleaned.
    If you have facebook, look for the toyota vios maintenance group. Ganyan discussion dun
    Dec 2016
    Try looking into the EFI system
    May 2008
    Quote Originally Posted by vorkalito View Post
    Hi sir. I'm aware that the problem is in the EFI but how do i go abt it? Any specific?
    May 2008
    Quote Originally Posted by sirkosero View Post
    Thanks sir, kakalinis ko lang 4 months (less than 4,000 kms) ago ng throttle body & MAF sensor. Will try cleaning ulit and will visit the fb page you mentioned.
    Yung fuel filter sir nagpalit na kayo?
    Sent from my SM-N7502 using Tsikot Forums mobile app
    Sep 2012
    Kapag ganyan pinagawa mo na physical checks and the problem is still persistent, I suggest magpa OBD scan ka na muna.
    It's just a little expense para malaman mo specific na papatignan once you get the results
    Sent from my Asus ZenFone 2 using Tapatalk
    Feb 2009
    Please define/describe erratic idling on a cold engine. The more details you have the easier the diagnosis
    Oct 2016
    Good Pm po, i have same issue nag punta ako sa dealership at nag pa diagnose ng issue, sabi nila I need to replace my MAF sensor, sobrang mahal ng piyesa, okay lang ba gumamit ng second hand na MAF? Mazda 3 2005 ung kotse ko.. Thanks sa mga sasagot
    Feb 2009
    Quote Originally Posted by pavila03 View Post
    What it is the airflow indication on the scanner? It should be around 1 gram per second per liter of engine displacement. Check other engine parameters. The engine vacuum should be between 17 and 21 inches of mercury. Use gauges, do not base your judgment on opinions and guesses
    Oct 2016
    Based on mazda mechanic, scanner shows that I have MAF sensor malfunction, I need to replace it as well as spark plugs and fuel filter also clean the throttle body. The new MAF is so expensive, is it okay to use a second hand MAF?
    If walang CEL, mechanical ang issue. I would try sa pinaka-madali... from spark plugs, fuel filter, fuel pump, fuel pressure regulator, etc. Mas madali sana if naka CEL.
Erratic idling on a cold engine
