Results 11 to 15 of 15
August 16th, 2007 12:38 AM #11
hi after putting the relay problem was solved pero after a few days parang may naririning akong ingay sa makina parang hangin na continuous na tsuk tsuk na mabilis.after how many days nag initiate start pero once i release the iginition after the crank ng engine mamamatay sya not unless i press on the gas tapos sabay hold ung break para lang di mamatay ung makina.den after that di na sya mamamatay....my auto is a matic na honda esi...dati original problem is nid i turn on ignition ng 3-5 times bago mag initiate ung crank...
previous changes nga pala is that naglagay ng relay and nagpalit ng end joint or somthing sa harap ang servitek. ngayon ko lang kac napansin na after u release the ignition namamatay kasama engine though it cranks this time na originilally it dosent...hope to here from you guys... thanks
August 16th, 2007 09:42 AM #12
Hi guys, baka me tip lang kayo regarding sa recent problem ng auto ko. Pag di ko sya nagagamit for 3-4 days, di ko na ma-start yung makina. Yung battery ko, motolite na kabibili ko lang at wala pang isang buwan. Yung auto ko kakapacheck up ko lang sa CASA (50k checkup) at wala naman silang findings. Pinacharge ko yung battery ko at pag na-start ko na yung engine, nagtry akong disconnect yung positive terminal ng battery to check my alternator, ok naman sya kahit buksan ko yung ilaw, aircon, etc.. Kaso pag di ko ginamit for 3-4 days humihina yung charge ng battery at ayaw ma-start ng engine. Any idea?
- Aug 2007
- 4
August 21st, 2007 12:02 PM #15
Pre i think the battery is the main problem ng car mo, sabi mo kabibili mo lang, maybe may factory deffect yan, Bring it to the nearest motolite sales office for testing and possible for replacement. Usually 2-3 years life spand ng battery at depende sa gamit mo. i currently replace my motolite battery and i use it for 3 years, nag crank pa nga siya pero i replace it na to be sure.
Xiaomi E-Car
